Engine Code P2262
Old Jan 4, 2014 | 07:14 PM
Mr.Dilac7.3's Avatar
Mr.Dilac7.3
Engine Code P2262
Hey guys, my dads 2004 6.0 threw up a code while he was on his way to work this morning. He went to Autozone to use their scanner and it pulled up code# P2262. Their explanation is its a faulty Turbo, and wanted him to purchase one in the store. He isn't very gullible and gave me a call when he drove home. So my question to you all is. What could be the problem. He stated that the thing ran like a top, and at no point did he ever lose boost pressure. He also said that his pressure was normal for his driving. I instructed him to look for a sensor, but like me, has no idea what he is looking for. A little help would be great.
Old Jan 4, 2014 | 07:19 PM
Fal-308-Win's Avatar
Fal-308-Win
P2262 turbo boost pressure not detected (mechanical) how many miles on the truck?
Old Jan 4, 2014 | 07:30 PM
Mr.Dilac7.3
The truck only has 104000 on the odometer. Last week he did have the FICM replaced and the mechanic stated that the EGR was clean. I did some more investigating and came across the ICP sensor being faulty or the MAP being clogged. Any clue on what the MAP is? I am not very educated on the 6.0
Old Jan 4, 2014 | 07:39 PM
Fal-308-Win
the map sensor is by the passenger fire wall hanging from the AC cover. the sensor doesn't get to dirty but the hose going to the intake manifold does. unscrew the nipple from the intake and clean with solvent. run some weed eater line down the hose to clear it out. time to clean the IAT2 sensor also. it's located behind the upper fuel filter, remove and clean with Carb. cleaner ,don't get solvent on the electrical part. there's 4 little windows in the tip, the upper two have small wires in them use a pipe cleaner and be gentle
Old Jan 4, 2014 | 09:42 PM
BLADE35's Avatar
BLADE35
the Hose to map nipple or intake probably came of or didn't get hooked back up maybe got knocked off or something simple
thelunkster
Mar 14, 2017 07:37 PM
WatsonR
Jun 12, 2015 12:59 PM
farmert
Mar 23, 2015 06:34 PM
SirPluto
Jun 3, 2013 12:12 AM
teague350
Sep 30, 2011 04:49 PM
