Learned something, Going to have to try the Auto 26 plugs. Currently running Auto 45 with a 68 302 w/ Holley 4bbl and Dura ll ign. it seemed I either had to clean the plugs too frequently, or replace. Swapped for smaller jets and now the plugs appear to be burning fine??
Just an FYI. While all modern FI systems have an O2 sensor most people running carbs don't think they can make use of them. By buying a wideband O2 sensor and installing it in the exhaust it can help you tune your carb and check your A/F ratio at various engine speeds and loads while on the road.
They cost around $200 but you can move them from car to car. The only thing that you have to do is get a bung for the sensor welded in to the exhaust pipe. When you remove the sensor just install a plug.
Neighbor has a collection of High Performance 60's vintage 'muscle' cars and installed 02 sensors in each; I am not that knowledgeable, he describes them as invaluable; particularly when it comes to fine tuning the early model quadrajet carburetors, which apparently are little more sophisticated when it come to adjusting the carburetor performance to the engine??
You'd have to check the part numbers, but 26's may not fit 68 heads.
