Grinding Noise
Old Jan 3, 2014 | 11:08 PM
laxxx's Avatar
laxxx
Grinding Noise
Still got some problems with my "new" 2000 Navigator.
When i drive down the street there is a grinding noise. you can hear it, when you drive faster than 20 mph at accelaration. i only have to tip on the speed-pedal and i can hear it. when i decalerate it takes three seconds and you can hear it again. it gets a little bit faster when i drive faster. sometimes it dissapeares when you drive down a bad road, but only for one second.
Brakes?
Front axle differential?
I know it is not easy to talk about subjective noises...maybe somebody had the same problem!!
Old Jan 4, 2014 | 11:05 AM
alloro's Avatar
alloro
Only when moving, or will it do it if you hit the gas in park?
Old Jan 4, 2014 | 11:08 AM
laxxx's Avatar
laxxx
Only when i am moving...
Old Jan 4, 2014 | 11:34 AM
alloro's Avatar
alloro
In that case I would first examine the brakes to see if they're worn down. There is a metal wear indicator tab on the pads. When this tab makes contact with a moving rotor you'd swear your front end is about to explode.
Old Jan 4, 2014 | 11:36 AM
laxxx's Avatar
laxxx
Ok...i'll check that first...thank you
mike1233
Oct 5, 2014 09:11 AM
kmc0929
May 1, 2013 11:10 AM
medic2586
2004 - 2008 F150
Nov 22, 2006 10:04 PM
deaddux
1997 - 2003 F150
18
Jan 17, 2006 08:50 PM
curtwalk
Mar 31, 2005 01:13 PM
