shift on the fly or ESOF as it is called is what you have.
vacuum operated to lock the hubs and an electric shift motor for the transfer case.
The hubs have two positions. Auto and lock.
Auto means they are disengaged till you turn the switch.
Lock is an alternate way should the vacuum system fail. You can get out and manually turn the hub to lock and then turn your switch to 4Hi and go. It is a redundant feature.
Neither method turns the front end into a locker differential. The front diff is an open diff so you can turn the front wheels.
Thanks that clears it up, i did not think that ford would do that but glad !!
The rear can be locked tho,, right ? I know read the Manual..lol I didn't get a chance to go through it yet i hope to over the weekend.
Track maintance and see recalls..link to pay your loan if you have ford credit and also sync
Go here and get an electronic copy of your window sticker: Untitled Page=
Thank`s for those link`s. the salesman at the dealer said that it will take a couple day`s but they will register the sink system or something,is the registration of this site what he was talking about ?
where to i get the password in info i will register myself! thank`s Will
Also the the dealers credit, we didn't set it up because it was a long day for me and the dealer they were moving cars all day and a big storm was coming in and it was snowing. I don't live that far and don't mind waiting to set it up. But if i could do it myself i would. Will
