Door handle shaft
Old Jan 3, 2014 | 05:29 PM
clinkfield's Avatar
clinkfield
Door handle shaft
Shaft is boogered up. Door handle is stripped. I want to replace the shaft and get a new handle. I see the shaft part several places.
On my truck, the arm is riveted onto the shaft part. How do I replace it? I don't have a way to put in a rivet.
Also - is there a "best" supplier to buy this from?
Here is the part on Dennis Carpenter:
Replace. Door Open Hand Shaft | Dennis Carpenter Ford Restoration Parts
Here is pic of mine:
[/URL]
Old Jan 3, 2014 | 05:42 PM
Becky_is_a_66's Avatar
Becky_is_a_66
I would bet all the repop places are getting the piece from the same import supplier. If carpenter says it is imported everybody else is most likely using the same source. I have bought "made in the USA" parts from other places and when it arrives it is wrapped in dennis carpenter packaging - they are one of the few that actually makes it stateside. You will need to drill out the old rivet and replace with a pin of some sort. Most of the home improvement places carry shouldered pins with a series of cotter/snap pin holes...you cut off to the length you need with a dremel and metal cut wheel or hacksaw; a spring washer b/w the two parts and spray lithium grease will help prevent binding.
Old Jan 3, 2014 | 07:32 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ford only sold the C1TB-8121818-B .. Door Lock Remote Control as a complete assembly. Right/Left is the same / Obsolete
Applications: 1961/66 F100/1100 / 1963/69 N/NT/T500/1100 / 1967/69 F800/1000.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 3 = 800-476-9653. No one else has any.
Listed under basic part number 21818 in pic:
Old Jan 4, 2014 | 06:27 PM
William's Avatar
William
These show up on ebay sometimes. Try googling the pn and you may find a supplier. And you can try the WTB ads here.
Splash440
Sep 16, 2017 08:21 AM
tractormanbill
Mar 27, 2015 09:34 PM
flying4fish
Apr 22, 2013 12:41 PM
calicofiftyseven
Jul 23, 2009 04:36 PM
Wheels331
Oct 24, 2005 01:24 PM
