Hello can someone give me some insight.MY engine light comes on when get on power ie;passing gear or towing trailer light stays on for a short time 5 to 10 minutes. If truck is shut off light does not come back on till you power up again. If you ease into it chances are light does not come on. Local Ford dealer has checked HPOP that test fine they clean the socks in the fuel tank. Now the dealer says it maybe a weak injector. Can anyone shed some Light. Yeah I know HAHA. Thanks RC
Did they bother to give u the code that it gives? That is the only real way to know what is happening. Sometimes a tuner can cause what u describe as well. Do u have one? How many miles on the truck?
I will ask for codes tomorrow.When they did the first diag. it pointed to the fuel system that's when they replaced the socks in the fuel tank. Tech is having a hard time pinpointing problem. This is the second time in 1 week the truck has been in the shop. Whatever the problem it does not effect the driveabllity.
All are original but 2 where replaced about 5 years ago and other work was done at the time but I'm having brain fade and can't remember what exactly was done. I have owned the truck since day one. I run either Delo 400 or Valvoline Prem.Blue. and in between oil changes i drop and replace the oil filter depending on how and where I'm driving
Sounds like this is going to get pricey. ? Is it possible to hang on till summer I would like to drop in a reman. Cost of new trucks are just out of hand
A reman is definitely possible. But you may get a lot more miles out of it. Have you noticed any oil in the fuel? Pull the fuel filter and look to see any discoloration. Any blowby?
Dead head pressure tested find. Dealer said that fuel pump tested at 30 psi under load and fuel pump needs to be changed. I replaced the pump the pump myself with one from NAPA.After all this light still come's on. Anyone have any ideas
Low fuel pressure can cause the 1211 code. Did you re-check it under load? If it's still low you probably have clogged screens in the fuel tank or an issue with the fuel pressure regulator.
