2002 Engine Light
Old Jan 2, 2014 | 07:09 PM
racord1's Avatar
racord1
2002 Engine Light
Hello can someone give me some insight.MY engine light comes on when get on power ie;passing gear or towing trailer light stays on for a short time 5 to 10 minutes. If truck is shut off light does not come back on till you power up again. If you ease into it chances are light does not come on. Local Ford dealer has checked HPOP that test fine they clean the socks in the fuel tank. Now the dealer says it maybe a weak injector. Can anyone shed some Light. Yeah I know HAHA. Thanks RC
Old Jan 2, 2014 | 07:48 PM
carltonwebb's Avatar
carltonwebb
Did they bother to give u the code that it gives? That is the only real way to know what is happening. Sometimes a tuner can cause what u describe as well. Do u have one? How many miles on the truck?
Old Jan 2, 2014 | 08:33 PM
racord1's Avatar
racord1
No chip or tuner truck is stock. Mileage 320k
Old Jan 2, 2014 | 08:41 PM
CampSpringsJohn's Avatar
CampSpringsJohn
Welcome to FTE! 320,000 miles! That's great! Is it still running the factory original injectors?
The codes will tell us a lot. If you got an invoice, it may be on there.
Old Jan 2, 2014 | 08:42 PM
racord1's Avatar
racord1
I will ask for codes tomorrow.When they did the first diag. it pointed to the fuel system that's when they replaced the socks in the fuel tank. Tech is having a hard time pinpointing problem. This is the second time in 1 week the truck has been in the shop. Whatever the problem it does not effect the driveabllity.
Old Jan 2, 2014 | 08:48 PM
CampSpringsJohn
Great! Just let us know what they are and we can help figure out the problem.
Old Jan 2, 2014 | 08:52 PM
racord1's Avatar
racord1
Okay here we go. They performed KOEO and KOER DTC P1211. ICP and IPR and harness tested ok. ICP Pressure not at desired IPR maxed out at 64%
Old Jan 2, 2014 | 09:23 PM
CampSpringsJohn
P1211 ICP Not Controllable - Pressure Abow/Below Desired
Is it still running the original injectors?
Have the injector o-rings been replaced at some point in time?
The reason for these questions is that with the mileage you have, you are beyond the life most people get on their factory original injectors.
How old is the oil?
What oil are you using?
Old Jan 2, 2014 | 09:45 PM
racord1's Avatar
racord1
All are original but 2 where replaced about 5 years ago and other work was done at the time but I'm having brain fade and can't remember what exactly was done. I have owned the truck since day one. I run either Delo 400 or Valvoline Prem.Blue. and in between oil changes i drop and replace the oil filter depending on how and where I'm driving
Old Jan 2, 2014 | 09:49 PM
racord1's Avatar
racord1
Sounds like this is going to get pricey. ? Is it possible to hang on till summer I would like to drop in a reman. Cost of new trucks are just out of hand
Old Jan 2, 2014 | 10:31 PM
CampSpringsJohn
A reman is definitely possible. But you may get a lot more miles out of it. Have you noticed any oil in the fuel? Pull the fuel filter and look to see any discoloration. Any blowby?
Old Jan 2, 2014 | 10:53 PM
racord1's Avatar
racord1
Small amount of blow by. Changed fuel filter about 4 weeks ago and no oil then
Old Jan 5, 2014 | 09:08 PM
racord1's Avatar
racord1
Dead head pressure tested find. Dealer said that fuel pump tested at 30 psi under load and fuel pump needs to be changed. I replaced the pump the pump myself with one from NAPA.After all this light still come's on. Anyone have any ideas
Old Jan 6, 2014 | 12:10 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
My guess is a leaky or sticking IPR with the P1211. Rebuilding the IPR is pretty easy and would account for an undesired ICP.
Old Jan 6, 2014 | 06:54 AM
tdpower's Avatar
tdpower
Low fuel pressure can cause the 1211 code. Did you re-check it under load? If it's still low you probably have clogged screens in the fuel tank or an issue with the fuel pressure regulator.
