Running Gear
Old Jan 2, 2014 | 09:18 AM
money pit 69's Avatar
money pit 69
Running Gear
Hello, just a little ?. I have a 69 f-250 camper special. Want to know if later year running gear( like 73 to 78 ect. ) will bolt right into truck. Like motor, trans, disk brake change, rear end. Is there info interchange site a guy can use. THX David
Old Jan 2, 2014 | 09:48 AM
JEFFFAFA's Avatar
JEFFFAFA
Right here! Use the search engine top of this page and you can research what other guys and gals have used.
Old Jan 2, 2014 | 04:01 PM
iggybob44's Avatar
iggybob44
Well, much of the stuff changes over pretty easy, are you talking about staying with 2wd, or are you looking into doing a 4x4 conversion? the 67-72's long bed, reg cabs had a 131" wheelbase, and the 73-79's went up to 133" wheelbase........Certain model F250 and F350 2wd's beginning in 68 or 69 came with front disk brakes.......Otherwise most of the running gear on a properly equipped 2wd F250 is pretty much just as good as on the later models, and the FE series engines on a 69 just might be better than what you might find on an emissions controlled late 70's truck. If your talking about putting your F250 Camper Special body on a later model 4x4 Chassis, 76 or 77 had front disks, the only thing real noticeable is the cab/bed gap with the longer wheelbase.
Old Jan 2, 2014 | 04:44 PM
money pit 69
Running Gear
THX for the comebacks, I have a 2 wheel which I'm staying with. The reason I'm asking is I may have a chance to pickup a 73 f-250 donor truck ($400.00). They say it has good running gear. I have not looked at it yet. One of the main things I want would be the rear end. ( a 60 Dana rear Diff., 3:73 Gears with a Power Locking true Poss locking Diff, Carrier. ) All of us 2 wheel drivers know these old trucks get stuck on wet grass. Also it has 4 barrel which I need . He claims the motor is 352 I though they only put 360 and 390 in 73 trucks. Also I may need the c-6 . Any comments and info. THX David
Old Jan 2, 2014 | 04:49 PM
JEFFFAFA's Avatar
JEFFFAFA
1967 was the last year for the 352. Someone in that truck's storied past might have thrown it in there though.
Old Jan 2, 2014 | 06:38 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1968/72 F250 2WD & F350 were available with optional dual piston caliper front disc brakes.
1973/79 F250 2WD: Power disc brakes were standard equipment, but there were two different types, as it depended on the GVW
Some have single piston calipers, some have dual piston calipers.
daves54
Apr 9, 2010 12:07 PM
78fordranger
Mar 10, 2008 09:26 PM
mike79ford
Dec 18, 2005 08:44 AM
cdorroh
Apr 1, 2005 12:10 PM
jstandle
19
Nov 15, 2004 10:47 PM
