New Guy needs help
Old Jan 1, 2014 | 09:11 PM
bigj0094's Avatar
bigj0094
I don't recall, all from Oreilys...........Fram i think ... the old ones looked clean and the new ones looked like the ones I replaced style wise
Old Jan 1, 2014 | 09:12 PM
mustang_309's Avatar
mustang_309
You need to run a bubble test to see if you have gases of combustion pushing into the fuel supply, secondly you need to have the dynamic fuel pressure tested as low fuel pressure is the most common source of injector damage, fuel pressure needs to stay above 45 psi at WOT ( wide open throttle ). You also need to use OEM oil and fuel filters and OEM oil filter cap. Using aftermarket oil filters can allow unfiltered oil into the HPO system and cause problems on the oil side of the injectors.
Old Jan 1, 2014 | 09:13 PM
04badford's Avatar
04badford
You noted o-reily oil filters , always use OEM or racor filters,Take a look at your oil filter cap is it Aftermarket cap? OEM is short the others are tall .I will see if I can pull up the two
Old Jan 1, 2014 | 09:34 PM
jswartz84's Avatar
jswartz84
OEM filters are always recommended. I noticed you were using Fram.
Old Jan 1, 2014 | 09:39 PM
mustang_309
Here is a video showing the difference between OEM and aftermarket filters,
Old Jan 1, 2014 | 09:58 PM
goosehunta's Avatar
goosehunta
dadgumit mustang
I was about to post that same video from dieselfiltersonline.com
owell its all good. very good video too
Old Jan 1, 2014 | 10:08 PM
04badford's Avatar
04badford
Brett do you have the OEM oil cap, I cant find it
Old Jan 1, 2014 | 10:51 PM
04badford's Avatar
04badford
Never Mind its in the Vid
Old Jan 1, 2014 | 11:51 PM
bigj0094's Avatar
bigj0094
Thumbs up
Thanks still not sure what to check with the rich fumes ...........will work on new filters tomorrow, and schedule diags of the injectors.............I will update progress.......thanks all for the help and if any idea's come up with why all the fuel is not burning let me know............I will update if my guy in AZ comes up with any answers.
Old Jan 2, 2014 | 01:12 AM
mustang_309
<p>
</p>
<p>The raw fuel is from a malfunctioning injector.</p>
Old Jan 2, 2014 | 01:20 AM
Edogsf350's Avatar
Edogsf350
hey mustang should he check to make sure the plugs are pushed in all the way?
Old Jan 2, 2014 | 10:59 PM
04badford's Avatar
04badford
X2 good call Brett, big Question for Big J do you use fuel additive if so How much 4 oz per every fill 22 gallons will do, Check the fuel Pressure and use OEM Filters ?
Old Jan 3, 2014 | 06:23 AM
  #28
mustang_309
That is certainly not a bad idea, I would check every electrical connection that had been touched during the repair.
Old Jan 4, 2014 | 01:59 PM
  #29
bigj0094's Avatar
bigj0094
I have had so much done on this truck...........I do use 4-6 oz of additive per instructions on the bottle.........Lucas is what I have been using.......I have used sea foam as well.. But I have had the Ficm off 5 times in the past 6 months...........I had an oil leak and had to remove it to fix the valve cover leak..... The plugs on the ficm have broken locking tabs but they seem to be all the way in........I was worried about them and have been looking at the new plugs ........( The weird thing is ...it runs good every morning and after 20 miles or so the # 7 inj.... has misfire and contribution balance codes show up ......some days # 4 shows up yesterday # 2 show up.......most days its only #7....... Schedule a Ford guy to hook up to ford scanner .......will update
Will it ever be over with these FORD 6.0's
Old Jan 4, 2014 | 02:01 PM
  #30
bigj0094's Avatar
bigj0094
I have been seeing this blue spring upgrade Should I be installing this as well
