What is this?
Old Jan 1, 2014 | 12:11 PM
Mustangking1's Avatar
Mustangking1
What is this?
I have had this truck since september but still have not figured out what this is. Truck is a 1978 F250 460 with a motorcraft 4350 carburator. It has some black electric tape wrapped on it since I bought it.
For a location view of it, it is on the passengerside valve cover in the middle of it.
Any help would be great!
Old Jan 1, 2014 | 01:24 PM
gatorfor88's Avatar
gatorfor88
I cant say for sure but it could be the air injection diverter valve. You could pull it and get parts number off of it and cross reference it.
Old Jan 1, 2014 | 02:18 PM
fmc400's Avatar
fmc400
MSEE
That looks like an electric vacuum solenoid. Those were pretty common in some of the more complicated pullover-type EGR or distributor advance control systems that took speed and ambient temperature into account. Could be wrong though.
Not it. That's a completely different animal.
Old Jan 1, 2014 | 02:23 PM
Mustangking1
Pulled it off, part number is pretty much gone off the part except D5somethingE with some other stuff underneath the D5.
It was only held on with 2 7/16 nuts, has two vaccum lines out the front that are not connected to anything.
Anyone else have a idea? Of what this is or what it connects to.
Old Jan 1, 2014 | 02:25 PM
fmc400's Avatar
fmc400
MSEE
Look up .
Old Jan 1, 2014 | 02:42 PM
Mustangking1
Lol, when i posted last it didnt show your post thanks FMC400.
Do you have a idea where it hooks up?
Old Jan 1, 2014 | 02:48 PM
fmc400's Avatar
fmc400
MSEE
In the limited cases I've seen, it's controlled via an amplifier under the dash, and interrupts a vacuum signal to the EGR valve (or something upstream), or somewhere upstream of the distributor vacuum advance. Your best bet is to look up the appropriate emissions diagram.
Old Jan 1, 2014 | 04:27 PM
V10man's Avatar
V10man
Now see I have always wanted to know what those stupid brackets were for on the valve covers. Now I know.
Old Jan 8, 2014 | 01:48 PM
TexinCali's Avatar
TexinCali
I think FMC400 is correct, vacuum solenoid, on my '78 460 is next to the vacuum amplifier and has to do with the EGR operation and maybe throttle kicker? Funny just this morning I was wondering if I could hook the EGR up directly to PVS and omit the amplifier and this solenoid.
This is with the old 4350 since replaced with a holley 4160, but you can see the solenoid with a little "cap" on it next the vacuum amplifier.
Old Jan 8, 2014 | 02:03 PM
Mustangking1
Do you or someone else have pictures of where the vaccum lines go and how it hooks up?
Old Jan 8, 2014 | 03:28 PM
ranger429's Avatar
ranger429
I believe that is specific to CA models only. The S/C I was restoring also had it and it was a Ca truck.
Old Jan 8, 2014 | 03:40 PM
Mustangking1
If it is then It interesting because my truck has it and it was sold originally here in oklahoma.
Old Jan 8, 2014 | 04:43 PM
psychlopath's Avatar
psychlopath
...This is with the old 4350...
Is there an engine under that??
Old Jan 8, 2014 | 06:16 PM
TexinCali's Avatar
TexinCali
Do a search for 'Fasthauler" he has a post with some great color coded diagrams showing the vac amp and egr.
I had mine hooked up per that post and it ran pretty well.
I have searched for a vacuum diagram for mine extensively and come up with some that seem pretty close but nothing that is an exact fit. I know there were several for each engine depending on vehicle weight, year, and options.
Old Jan 8, 2014 | 06:24 PM
ranger429's Avatar
ranger429
That is what your DSO code states?
