Which gasoline?
Old Jan 21, 2014 | 10:15 PM
  #31
abe's Avatar
abe
Would you advise to use a stabilizer, like Lucas Oil makes, in your tank. Would it help counteract the negative effects of the ethonal?
Old Jan 22, 2014 | 07:05 AM
  #32
raerjim's Avatar
raerjim
Abe, there are outfits that make Ethanol stabilizer, Star Brite, Sta-bil among others. Alleged to "help prevent" phase separation, wherein when water is introduced into a gas tank with gas and e-10, the gas and e-10 will absorb water until saturated, then the water will separate and find it's way to the bottom recesses of a given gas tank. If your fuel pickup is low enough, you've got problems. What we need is an additive that REMOVES ethanol. If possible, only run non ethanol fuels in your Baby. I run the "stabilizers" in both my boats here in Florida and in any stored gas.
Old Jan 22, 2014 | 03:55 PM
  #33
AXracer's Avatar
AXracer
I suspect that the "stabilizers" are just more alcohol like dry gas to dissolve any excess water. I really doubt they do much to help the deterioration of rubber problem or the auto manufacturers would be recommending them and/or the refineries would be adding it to their gasahol.
Old Jan 22, 2014 | 05:26 PM
  #34
Olweldinrig's Avatar
Olweldinrig
I know since I started using premium in the wippersnipper,snowblower,lawnmower,chainsaw and the snowmobile when its time to start every thing in the new season I don't hardly ever have a problem starting anything.When I leave the cheap fuel in anything I usually allways have a carb or two that needs removal and cleaning.
3twinridges
27
Jun 18, 2018 10:49 PM
lafermedavid
27
Dec 22, 2016 03:46 PM
easyrider47
15
Aug 18, 2014 11:31 AM
1994 F250: 351, C6
38
Mar 11, 2009 03:25 AM
