302 ignition problems
Old Jan 4, 2014 | 08:26 PM
ColtonMullis's Avatar
ColtonMullis
Alright. I rewired the wires running to the distributor from the ignition box. It seems that there was a short in one of the wires.causing it to break the circuit going to the coil. Problem fixed. It still ruins rich though. ):
Old Jan 4, 2014 | 10:31 PM
Dave145's Avatar
Dave145
Running rich is a carb thing, but glad to hear ya figured it out.
Old Jan 4, 2014 | 10:37 PM
ColtonMullis
I still think i need hoter burning plugs. I'll see how the ones i have work for about a week.
Old Jan 4, 2014 | 10:51 PM
Dave145's Avatar
Dave145
Why not toss in the stock type plugs? For example I run exclusively Motorcraft/Autolite ASF-42 plugs. The stock plug type should be on your valve cover sticker.
Old Jan 4, 2014 | 11:31 PM
ColtonMullis
That might be what i end up doing. Ford wouldn't put them in there if they were not going to work right.
Old Jan 5, 2014 | 12:15 AM
Dave145's Avatar
Dave145
If you're running rich though, still sounds like your carb or choke may be out of adjustment. Might wanna try tuning it. No offense intended here but, do you know how to tune it?
Old Jan 5, 2014 | 12:21 AM
ColtonMullis
Yeah i do. But i think the temp change could have affected the choke. I'll probably lean the choke and air/fuel mix up a bit.
Old Jan 5, 2014 | 12:28 AM
Dave145's Avatar
Dave145
I was thinking the same thing about the temp change.
Old Jan 5, 2014 | 12:31 AM
ColtonMullis
Whenever i quite driving it ran fine. Its been about a month and it has went from 50 degrees to high 20s.
Old Jan 5, 2014 | 12:33 AM
Dave145's Avatar
Dave145
It went from high 30's to single digits here in southern Wisconsin. Oddly enough my truck only required minimal tuning to get it to run right in these temps.
Old Jan 5, 2014 | 12:52 AM
ColtonMullis
Wow. We don't get temps like that here in georgia. It shouldn't take no more than a quarter turn on each side.
Old Jan 5, 2014 | 12:57 AM
Dave145's Avatar
Dave145
I agree shouldn't be too much. Yeah right now its 21 degrees but feels like 4. As of Monday it will be -13 as a high with wind chill values of -50 degrees. My truck and its 10wt40 oil are gonna LOVE me!
Old Jan 5, 2014 | 01:03 AM
  #28
ColtonMullis
I run straight 30 weight so when temp changes it doesn't really change the oil.
Old Jan 5, 2014 | 01:14 AM
  #29
Dave145's Avatar
Dave145
With that weight, I've found it doesn't change much. However with the 40...that stuff is literally like tar in my oil pan.
Old Jan 5, 2014 | 04:23 PM
  #30
ColtonMullis
I turned my a/f mix screws in about 3/8 a turn. It runs great now with about 25% quicker response time. Now is time to fix my motor mounts because all that revving trying to keep the motor running wore the bushings out.
Piston Honda
Jul 13, 2019 11:06 AM
big_tuff
1997 - 2003 F150
Sep 19, 2006 10:49 AM
95fordbronco302
1978 - 1996 Big Bronco
Apr 2, 2002 04:17 PM
lew11998
Jul 27, 1999 06:13 PM
