2006 F250 PowerStroke front axle bearings
I'm new to the forum so please bear with me on stupid questions. I like to do as much work myself as I can on all my vehicles and have been doing much of the maintenance on my 06 Super Duty 6.0 diesel. I have a simple shop with a lift so I can get into more work than the average driveway / floor jack guy. Enough with the BS.
I recently had an issue with front end groaning and here's a quick rundown of where I'm at:
1. Rebuilt the front end almost exactly two years ago (hub bearings, seals, stub shaft u-joints)
2. Recently got some snow up here and plowed my driveway after a two year lack of plowing (gave up my commercial contracts) and noticed a front end growling, especially under deceleration and just figured wheel hub bearings had gone bad. I had previously plowed heavily since it was new in 06' so I was a little skeptical of the wheel bearings being bad since the new ones were installed two years and about 27,000 miles ago, but it sure sounded like it fit the bill.
3. Replaced both hubs and growling still there. Talked to my mechanic buddy (who I need to use from time to time when it gets too involved) and he told me it's more than likely the "front axle bearings". Sounds like it happened to his 04 Super Duty too.
So my questions are these:
1. Has anyone had to replace these before (these are the ones inside the front pumpkin) and if so, how difficult was it?
2. Anything else I should do / check while doing this? I would probably do the driveshaft u-joints just as a point of fact while it's out.
3. I found some simple Ford parts schematics and wondered if anyone has any special schematics they recommend.
Doesn't sound like it's something I need to do tomorrow, but I also don't want to get myself broken down as it's sounding like more snow is coming and I sold my other F250 gasser last month so this is my only vehicle. Any help / suggestions would be greatly appreciated. Hope this forum is helpful and informative.
Take the tire off and spin the unit bearing it should roll easy and smooth
My Wife pulled in the driveway last night at 9pm and said my Car is Grinding
It took me till 1 am to install UNIT BEARING with a Flashlight on her car LOL
I couldn't believe I had one laying around LOL
But it didn't Roll SMOOTH at all Sounded like the ABS Sensor came apart inside pretty loud grind
OK, I don't think I'm being clear, or maybe misunderstanding the responders. I replaced both hub bearing (foolishly as they probably weren't bad to begin with) and my next repair needs to be the axle bearings inside the front differential case. These would be where the half shafts enter the case at the gears.
housedad
09-18-2011 11:52 PM
MATTRESS GUY
15
11-26-2007 03:09 PM
