Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
engine swap
Old Dec 30, 2013 | 11:44 AM
fordtmm's Avatar
fordtmm
engine swap
I have a l800 ford truck with a 391 I am looking at a 3208 cat is the swap possible has anyone on here done something like this?
Old Dec 31, 2013 | 07:52 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
First thing is to look at what your truck may have come with from the factory. Did the L800's ever come with a diesel?
Old Dec 31, 2013 | 01:48 PM
dmanlyr's Avatar
dmanlyr
A very doable swap, the diesel versions were the L8000's. However there s a bit more than just a engine swap, you will need to deal with the gearing as well. If you have juice brakes, you will need to deal with a vacuume pump as well.
Not sure it really is worth the effort though, unless he L800 you have is incredibly good condition, or set up as a one off type rig that has a specialized function as already set up L8000's with the 3208 are readily available. Many older good diesel trucks are coming out of CA as they cannot be registered / used without modification to meet the particulate standards, and that is if the manufacture even offers a retro fit kit.
I think if I were going to put forth the effort and cost to do a diesel swap it would be a with something that has a bit better reputation, and more importantly is a linered engine so rebuilding is practical.
Just my thoughts, David
Smirks90
Connecticut Chapter
Apr 28, 2016 08:32 PM
seanrangerdanger86
1983 - 2012 Ranger & B-Series
15
Apr 3, 2012 09:32 PM
bigdummyford
Minnesota Chapter
18
Oct 1, 2009 10:47 PM
99F150
1997 - 2003 F150
Apr 27, 2004 09:13 PM
phantom429
Alberta Chapter
Dec 29, 2002 06:21 PM
