Torque setting for the wheel bearing mounting bolts is either 130 or 133 ft lbs. u could double check on tat. Best of luck sal. Wish u was nearer. I'd give u a hand on tat any day.
Crazy question...does my 2004 F-350 have fine threads or course threads on my hubs??
my early 04 had fine threads
found in a thread somewhere when I was looking for that answer that:
1.5mm = Fine
2.0mm = Coarse
from peak to peak, I took a lug off put a piece of masking tape across the thread took it inside and measured. Hard to tell if it was at the .5 mark or not so I just looked to see if it lined up at 3.0 for two peaks, much easier.
I am waiting on that very hub to come in still, also used that thread as a reference to purchase it
Sent from my iPhone using IB AutoGroup
Appreciate your help Dom! Thank you.
1.5mm = Fine
2.0mm = Coarse
from peak to
I am
to purchase it
