ABS question..
Old Dec 30, 2013 | 07:24 AM
SteelerSal's Avatar
SteelerSal
'04 F-350 6.0
ABS question..
Been having an issue with my ABS. I know that my front hubs are needing to be replaced and recently my ABS light came on and my braking is kinda wierd (pulling bad to the left)
Can bad hubs fool with my ABS?
Old Dec 30, 2013 | 09:42 AM
nighthawk285's Avatar
nighthawk285
Yes. If the bearings are getting loose and pivot in their races, it will also throw the tone ring out of alignment. With the tone ring out of alignment your ABS won't function properly.
Old Dec 30, 2013 | 09:44 AM
SteelerSal's Avatar
SteelerSal
'04 F-350 6.0
Great. Thanks for your reply.
I'm hoping this is the issue since I know my hubs are bad.
Old Dec 30, 2013 | 09:49 AM
nighthawk285
I'll bet it is....also if the bearings are grinding and throwing debris, the shavings will start to mess up the signal for the magnetic pickup sensor for the ABS...either way, I'll bet its your hubs.
Old Dec 30, 2013 | 09:52 AM
SteelerSal's Avatar
SteelerSal
'04 F-350 6.0
Gonna give this a try then.
Appreciate your help.
Old Dec 30, 2013 | 10:09 AM
SteelerSal's Avatar
SteelerSal
'04 F-350 6.0
Crazy question...does my 2004 F-350 have fine threads or course threads on my hubs??
Old Dec 30, 2013 | 10:38 AM
nighthawk285
lol, don't know, you'd have to go look. The majority of the truck's I've seen have coarse threads, but some do have fine. Can you take a picture?
Old Dec 30, 2013 | 10:40 AM
SteelerSal's Avatar
SteelerSal
'04 F-350 6.0
Unfortunately my truck is home, 40 miles from work.
Old Dec 30, 2013 | 10:56 AM
nighthawk285
Well other than looking at them I don't think there's an actual way to know. So you've got a 50/50 chance and IF you're wrong, you can always just pound out your old studs and put them in the new hubs.
Old Dec 30, 2013 | 12:04 PM
9228.bobcat's Avatar
9228.bobcat
May want to check your brake pads as well. That will throw an abs light and will cause to pull one side or the other.
Old Dec 30, 2013 | 12:06 PM
SteelerSal's Avatar
SteelerSal
'04 F-350 6.0
Will do..
When I get home to the truck i'm gonna pull the wheels and inspect.
I replaced a caliper on the passengers side and the pads and rotors a couple months ago.
Old Dec 30, 2013 | 12:14 PM
9228.bobcat
You didn't replace the driver side brakes?
Old Dec 30, 2013 | 12:15 PM
SteelerSal's Avatar
SteelerSal
'04 F-350 6.0
Yeah I replaced front brakes, both rotors and passenger side caliper.
Old Dec 30, 2013 | 12:17 PM
9228.bobcat
That shouldnt be it then. Unless that new caliper is sticking.
Old Dec 30, 2013 | 12:19 PM
SteelerSal's Avatar
SteelerSal
'04 F-350 6.0
Since I have to see if I have fine or course threads I will pull both tires and inspect anyways.
