Sponsored by: Real Truck
Front ABS Question.
Old Jan 28, 2008 | 12:43 AM
molotov's Avatar
molotov
Front ABS Question.
This is the second time I am posting.
I have about 225K on my truck, and I need to replace the front hubs. Are all the ABS components located in the front hub assemblies? Can I convert my non-front ABS truck to ABS by buying ABS hubs?
Any help?
Old Jan 28, 2008 | 07:40 AM
rugermack's Avatar
rugermack
Yes, the ABS sensors are located in the hubs. I don't know if your trucks computer will support it, if it wasn't stock. There is also a second harness that goes from the sensors to ? Mine hasn't broken yet, so not sure about your upgrade question.
Old Jan 28, 2008 | 11:33 AM
Mercury45's Avatar
Mercury45
I know on 99-08 the front sealed unit wheel bearing assy's have the ABS sensor and the sensor "tone ring" inside the sealed assy.
For you to make your non-stock abs truck able to have abs up front would be more trouble then it is worth in my opinion.
Do you really want abs? I hate mine
kenny
Old Jan 28, 2008 | 02:44 PM
Sebs's Avatar
Sebs
kenny
Why do you hate it?
Old Jan 28, 2008 | 05:39 PM
Mercury45's Avatar
Mercury45
I go places where there is snow built up on top of "icey" roads. The abs always enguages when I dont want it.
If I lock up the wheels in a stright line the snow will form ramps and stop the truck faster and more effectively then ABS can imagine.
Same thing for mudding / offroading. Ever get into a situation where a few wheels are slippin and the others grabbin... ABS gets in the way big time
Thats why i hate it.
I feel safer without it. I can feel the truck sliding out, when that happends let go of the brakes and try again... or if your going stright, and snow is getting built up under the wheels then keep letting it do so.
Thats why i hate my abs, but i guess for most people its wonderful. I just want to be in control, back before ABS people knew how to drive and handle sliding conditions, now people rely on the technology too much in my opinion and so people do not need to learn how to drive as well.
But abs does not help if under power and sliding....
Kenny
Old Jan 28, 2008 | 06:35 PM
rbaker6336's Avatar
rbaker6336
I realy like my anti-locks,in Fla when roads are damp the are like driving on ice and the last thing you want is a brake to lock,I nave never had mine lock and that's what I want
Old Jan 28, 2008 | 06:41 PM
Mercury45's Avatar
Mercury45
to each their own, its what makes the world go round and round
kenny
Old Jan 28, 2008 | 06:53 PM
molotov's Avatar
molotov
Thank you for all the replies. The wiring for the ABS is there. I wouldn't mind having the ABS. We don't have snow here often, and I like having the control in a full brake situation.
I have found a few things in my truck, that Ford just didn't add as an option, but once you plug it in, it works fine.
Old Jan 28, 2008 | 07:01 PM
Mercury45's Avatar
Mercury45
dont know if you can even get the sealed assys without the abs, they cost about 260 - 280 here with the abs sensors... good luck kenny
Old Jan 28, 2008 | 08:45 PM
Wayne64SS's Avatar
Wayne64SS
I believe you would need the new ABS hubs and sensors. All the wiring shoudl be there, so then all you have to do is replace the entire ABS controller as well as the ABS Modulator (that electronic valve assembly). Then you will need the lines etc from the front of an ABS truck. Way more trouble than its worth at 225k.
Old Jan 28, 2008 | 09:20 PM
Mercury45's Avatar
Mercury45
thats my thought too... you could look at the abs module - but if it is setup for only rear abs the front ones wont do squat until ford reflashes that abs module... 225K not worth it in my opinion.
just practice driving in slick conditions - i guess i take it for granted living in new jersey we get crazy weather up here and we have to get used to it
kenny
