1345 bw chain slack?
Old Dec 30, 2013 | 03:04 AM
75Three90's Avatar
75Three90
How much chain slack should be in a 1345 bw? There is no stripped or chipped teeth on the he "sprockets" or "gears" but the chain seems loose
Old Dec 30, 2013 | 03:10 AM
75Three90's Avatar
75Three90
Oh yeah we ts in a 1989 f250 5.0 5 speed
Old Dec 30, 2013 | 06:39 AM
dixie460's Avatar
dixie460
If there ain't any rub marks on the case, and it doesn't look like there will be anytime soon (chain not dangerously close to rubbing) then I'd just call it good.
When I rebuilt my "new" manual shift BW1356 the chain wasn't even close to rubbing or jumping off the cogs so I reused it. Working great to this day.
Old Dec 30, 2013 | 02:23 PM
75Three90's Avatar
75Three90
Thanks buddy its about 2-3 inches from the case so I'll put it back together.
Old Dec 30, 2013 | 08:43 PM
eakermeld's Avatar
eakermeld
Do the pump improvement trick while you are in there. Won't cost a thing.
Old Dec 30, 2013 | 08:57 PM
75Three90's Avatar
75Three90
How do I do that?
Old Dec 30, 2013 | 09:02 PM
eakermeld's Avatar
eakermeld
That little V-shaped piece on the pump that goes against the case, you weld a rod or bolt in it so it doesn't wear prematurely and spin the pump. Do a Google search on bw1345 pump or bw1356 pump. You will find it.
Old Dec 30, 2013 | 09:05 PM
eakermeld's Avatar
eakermeld
BW 1356 Transfer Case Problem - FSB Forums
Scroll down in this article and you will see it.
Old Dec 30, 2013 | 09:24 PM
75Three90's Avatar
75Three90
I don't rember my case looking g like that
Old Dec 30, 2013 | 10:11 PM
eakermeld's Avatar
eakermeld
Maybe it's just the 1356 that gets that way, I forget!
Old Dec 30, 2013 | 11:54 PM
75Three90's Avatar
75Three90
My case doesn't have that style of pump. I have the 1345 that was supposedly used from 1980-1988 and only transferred over to the bronco in 89 yet my 89 f250 has one.
Fords4Me
Mar 7, 2015 10:22 AM
fordsrgrt
Jul 31, 2007 09:49 AM
Rob Cuenin
Dec 19, 2005 04:02 AM
scouterspokane
Dec 10, 2005 07:34 PM
YingxYang
Aerostar
Dec 30, 2003 10:38 AM
