I need help on lights wiring
Old Jun 25, 2003 | 08:36 PM
shane43028's Avatar
shane43028
I have a 78 F150 4x4 with a 351m.Drove at dusk tonight to find out no tail lights,no brake lights,no turn signals,and one head light and just a couple side marker lights.Kinda scarry trip home.
Any ideas?Where can I find a wiring diagram?Where should my wires be found?
Any help would be appriceated
Old Jun 25, 2003 | 08:53 PM
Mil1ion's Avatar
Mil1ion
I would say a headlight and marker lights are burnt out.
Check the fuses first then get back to us.
Old Jun 25, 2003 | 08:54 PM
shane43028's Avatar
shane43028
Will check em right now
Old Jun 25, 2003 | 09:03 PM
longview1's Avatar
longview1
Banned
same thing happened to me, except headlights,
turned out to be a wire disconneccted along the line, check wires and ground wires too,they frit out sometimes, just my .02$
cheers
Old Jun 25, 2003 | 09:14 PM
shane43028's Avatar
shane43028
Okay no fuse problems now temporarily wrapped em in alum. foil got a spotter and now i'm really baffled.
1 tail light till I hit brakes then goes out (so no tail light OR brake light,thenlet off brake light and tail light stays out too??????????
Old Jun 25, 2003 | 09:17 PM
theonlybull's Avatar
theonlybull
first, check your grounds.... tail light goin out like that is usually a sign of bad ground.
then get back to us
Torque1st's Avatar
Torque1st
Posting Legend
Bad grounds, typical problem.
Get that aluminum foil off your fuses, -bad idea
Old Jun 25, 2003 | 09:27 PM
shane43028's Avatar
shane43028
I will ,as I said just a temporary fix as I didnt have any fuses here.
Thanks guys
Will mess with stuff in the day light tomorrow and get back to yas
Old Jun 25, 2003 | 10:58 PM
Mil1ion's Avatar
Mil1ion
Eric, never said you can start a fire by wrapping fuses with tin foil.
Old Jun 26, 2003 | 03:55 PM
shane43028's Avatar
shane43028
well its not the ground.sanded and scuffed everything.had left turn signal working for a few but.........
now i at least have 1 brake light that is till i turn my lights on then it goes out. i can really do without turn signals(id probably get flipped off for my driving style anyway but i really do need brake lights tail lights and headlights
Old Jun 26, 2003 | 04:14 PM
73Custom's Avatar
73Custom
Check out this tech article about light trouble shooting and repair. It's about a '70, but yours will be almost identical.
Marty
Old Jun 26, 2003 | 04:53 PM
shane43028's Avatar
shane43028
i owe ya one marty!thanks.
if i can only fix what ive probably allready tore up/out ill have it
kupiec20
21
Jul 8, 2013 12:12 PM
rb8484
Jan 22, 2013 10:17 PM
86'F-150
Jan 14, 2013 10:48 PM
Nick Greer
13
Aug 13, 2012 10:57 AM
filelicker
Jul 6, 2006 04:37 PM
