Water pump replacment
Old Dec 29, 2013 | 02:39 PM
goosehunta's Avatar
goosehunta
Hat does everyone use as a replacment. OEM?
Or whatever is at the parts store.
Sent from my iPhone using IB AutoGroup
Old Dec 29, 2013 | 02:40 PM
npccpartsman's Avatar
npccpartsman
Something with a metal impeller. This is one case I won't recommend OEM. Bulletproof makes a nice one but it's pricey.
Old Dec 29, 2013 | 02:51 PM
goosehunta's Avatar
goosehunta
In what ways does the water pump fail. I have heard that the impeller will crack. I think mine was leaking at the freeze plug and the vent hole. But it's not cracked.
Old Dec 29, 2013 | 03:19 PM
npccpartsman
Impeller cracking or coming loose is by far the most common that I've heard of. I think most if not all the aftermarkets are metal impellers so it should be easy to find and may have a "limited lifetime warranty".
Old Dec 29, 2013 | 05:42 PM
Unrealo4's Avatar
Unrealo4
I found one at checker that had a metal impeller and cost a grand total of $14. Its been on for about 60k and doing fine. My old one failed because it started leaking coolant from the hole under the the wheel.
Old Dec 29, 2013 | 06:36 PM
goosehunta's Avatar
goosehunta
thanks for the info. mine was leaking from there. I had a morning a couple weeks ago and it puked almost all the coolant out of the system. it was soaking wet all over the place. I couldn't find anywhere else it could have been leaking from.
Texas Bob
Jan 24, 2020 11:37 AM
ItsMREMT
Sep 20, 2013 08:09 PM
true blue
Jan 20, 2011 09:36 AM
Polkster
Mar 12, 2009 04:39 PM
65fordguy
44
Feb 12, 2008 09:59 PM
