ok what cam?????
Old Dec 29, 2013 | 11:11 AM
derbydad276's Avatar
derbydad276
ok what cam?????
I scored a low mile 400 from a 1971 galaxie
being a 71 I should have 9 to 1 pistons
I know the engine makes 400 ft lbs of torque which is plenty for my 3500 lb pick up
I'm thinking of jerking the heads and having them redone with hardened seats because they came out way before unleaded fuel
the truck will mostly be a driver making 1 maybe 2 trips a year to the drag strip
what cam is suggested to maximize economy! while not sacrificing horsepower?
I plan on leaving the iron manifolds on the engine running dual exhaust
and adding a 4 barrel intake and electronic ignition
Old Dec 29, 2013 | 02:47 PM
80broncoman's Avatar
80broncoman
What gears?
Stick shift ?
if auto trans, stock converter?
what is the RPM your going to shift at?
Old Dec 29, 2013 | 02:58 PM
Cole Neese's Avatar
Cole Neese
If you want economy, jerk the iron manifolds off and get headers. I went from 10 to 14mpg when I put my Hookers on. As far as the cam goes, like broncoman said we need more information. Or you could call COMP or Summit, I've heard they both do a good job with cam selection advice.
Old Dec 29, 2013 | 04:04 PM
derbydad276
sorry
c6 stock converter
if I did add a converter it would only be 1800 to 2200 stall (just over stock)
shifting ? not planning on reving the engine over 4500
Ill have to dbl check my new rear Im installing a IRS from a tbird I think its 3.23
I would like to stay away from headers simply for the reason of (blown header gaskets)
I planned on hanging a free flowing dual exhaust system with glass packs (smithy's)
I'm building something to drive the snot out of not a race car
so what are you running?
I just want too open it up and let it breath
Old Dec 30, 2013 | 10:44 AM
Cole Neese's Avatar
Cole Neese
I have a C6 with the stock converter too. Right now I'm running a COMP High Energy 252H grind that I just swapped in. I really like it so far, woke the motor up a lot compared to the stock emissions cam. I haven't done a mileage test on it yet but I know it's got loads of torque all the way from idle to 3500, which you will probably need with 3.23 gears. When you say free flowing exhaust, what size are you talking?
Old Dec 30, 2013 | 12:18 PM
BuzzLOL's Avatar
BuzzLOL
. With only 9:1 compression ratio, prolly don't want much bigger than a 204/214 duration at .050" lift cam... Summit K5200, Comp HI252H, etc. fine... use stock converter, pull hard from 1000 RPMs... give peak torque around 3400-3800 RPMs... HP peak around 4800-5000 RPMs... shift by about 5500 max... bigger cams will bleed off too much compression/MPG/torque...
http://www.summitracing.com/parts/sum-k5200/overview
. Stock cam was prolly about a 184/194 or 194/204...
. Unleaded gas was around in 1971, so you may have hardened valve seats already... especially since your engine was a new for 1971 design (first ones produced in late 1970)... might do a compression check on all 8 cylinders... if any much less than about 125 psi, may have a burned valve/seat...
. I'm driving a '78 Ford F150, SuperCab, 4WD, 8' Bed, Western SnowPlow, 351"M/C6/3.50:1 front/rear that I want to convert back to a 400"/408" with modified KB149 11:1 pistons, 214/224 cam or maybe the Summit Racing K5201 218/228 cam, 4bbl., headers, true dual 3" S.S. exhaust, Dual 3" Dodge Hemi Truck mufflers...
http://www.summitracing.com/parts/ue...9-std/overview
http://www.summitracing.com/parts/sum-k5201/overview
Old Dec 30, 2013 | 08:23 PM
derbydad276
thank you for the info
sounds like what Ill copy
2 1/4 pipes glass packs weiand intake holley 600 c 6
Old Dec 30, 2013 | 09:54 PM
Cole Neese's Avatar
Cole Neese
Yep, no problem. Sounds like we are running pretty much the same thing except my truck is twice as heavy, has 4.10 gears, 1/4in bigger exhaust and headers. I'm not guaranteeing that this is a great cam for your application I just know it is for mine, as I said I'm not sure what kind of mileage it gets. I'm hoping for 14 since that's what it got with the stock cam and retarded cam timing but that may be a little too optimistic.
a63unibody
Oct 30, 2010 02:56 PM
wyldstallyn73
Jun 20, 2005 01:41 AM
278broncos
Apr 19, 2004 07:26 AM
thatdude
Dec 21, 2003 01:55 AM
trinogt
Jul 17, 2002 12:12 PM
