Manual to automatic help please
Old Dec 28, 2013 | 10:49 PM
sluggo 36's Avatar
sluggo 36
I searched several threads to find this answer but no luck yet. I have a '79 F250, 460, manual that I want to switch over to a C6. As I understand it, any 400 or 460 4x4 C6 will work? Are there two different output shaft lengths? I'm in Alaska so I'd like to get the parts right the first time. My list:
auto steering column
different brake pedal assembly
kick down linkage
flex plate
neutral safety switch wiring
I'm having my left knee replaced so the clutch has got to go!
Thanks in advance!
-Rob
Old Dec 28, 2013 | 11:00 PM
75Three90's Avatar
75Three90
You shouldn't have any wiring to your trans at all. You may also need a different drive shafts and cross member. If I rember correctly you should have a t-18 if so the t-18 is shorter than a c6.
Old Dec 28, 2013 | 11:09 PM
sluggo 36's Avatar
sluggo 36
Thanks for the info.
Old Dec 28, 2013 | 11:12 PM
75Three90's Avatar
75Three90
Also don't spend extra cash on getting your pedals switched when you unhook your linkage just leave the clutch pedal in there it'll fall to the floor.
Old Dec 29, 2013 | 04:08 AM
Rusty_Old_F250's Avatar
Rusty_Old_F250
If you want to get around replacing the column you can get one of these:
Lokar: Automatic Transmission Shifters
You can also disassemble the brake petal assembly and remove the clutch petal.
Any parts store should be able to get a flex plate for you.
Sam
Old Dec 29, 2013 | 08:13 AM
Drac's Avatar
Drac
Save the old ones
I think the starters are different between the manual and auto.
Auto cooling lines typically go through the radiator for cooling. Either you'll have to swap out the rad or add a trans cooler to the front of it.
Best to find a similar year donor truck.
Old Dec 29, 2013 | 11:11 AM
75Three90's Avatar
75Three90
I would go with an external trans cooler
They are relatively cheap
mabigredtruck
Nov 11, 2010 06:16 PM
JDWIS
18
Oct 26, 2005 11:52 PM
Halibut4
Sep 16, 2003 09:58 AM
ackusackus
Aug 17, 2002 11:41 PM
rc_brooks
Nov 24, 2001 12:30 PM
