power!!!
Old Dec 28, 2013 | 01:37 PM
bluesnake2006's Avatar
bluesnake2006
power!!!
looking for some easy cheepish upgrades that will make my truch have a little more power and run better over all. looking for some new ideas. thanks for any help.
its a 1986 f150 regular cab base model with the 300 4.9L
as far I know its all more or less stock no major upgrades..
Old Dec 28, 2013 | 01:41 PM
Conanski's Avatar
Conanski
Synthetic fluids in everything.. engine, trans, differential.
Do a tuneup and advance the base timing a few degrees.
Old Dec 28, 2013 | 03:11 PM
Franklin2's Avatar
Franklin2
Here we go again. How much stuff is unhooked under the hood(wires, vacuum lines, etc.)
Old Dec 28, 2013 | 04:38 PM
ctubutis's Avatar
ctubutis
And when is the last time you pulled the computer codes....
Old Dec 28, 2013 | 04:52 PM
bluesnake2006
there are no computer codes that I know of.. theres no light on on the dash or anything.. and I cant find anywhere to hook up a scan tool maybe you can help me with that..
and as far stuff un hooked I went true he vacuum digrams and fixed all open ends. the only open hoses are to the air pump for exaust that was removed.... not sure if that's affecting anything...
and the only wires are like large plugs that don't apper to ever have been pluged in....
Old Dec 28, 2013 | 05:14 PM
ctubutis's Avatar
ctubutis
These will get you started:
Fuel Injection Technical Library » How To Run a Self-Test
Ford Ranger/Bronco II EEC-IV Testing
Old Dec 28, 2013 | 05:21 PM
bluesnake2006
my truck is a carburetor model not fuel in jection and I if I read right those are for efi
or an I reading wrong?
Old Dec 28, 2013 | 05:59 PM
ctubutis's Avatar
ctubutis
You have a computer-controlled Feedback Carbuetor as well as a computer-controlled ignition. So, yes, pull the codes....
KOEO
CM
KOER
Old Dec 28, 2013 | 07:53 PM
bluesnake2006
alright ill give it a try tomorrow if it dosent snow over night lol
reddraven1978
Apr 3, 2008 09:54 PM
Badassmechanic
Dec 31, 2007 10:24 PM
BigJonBear
17
Jul 4, 2007 03:14 PM
brents
Dec 4, 2001 08:15 AM
