prothane control arm bushings
Old Jun 25, 2003 | 04:27 PM
gtex's Avatar
gtex
I'm pulling my control arms, but the bushings in my kit from ProThane (JC Whitney) don't look as thick. Anybody used these? They are labeled appropriately.
Old Jun 25, 2003 | 04:46 PM
BB's Avatar
BB
This might sound dumb but why not give them a call, it's toll-free (1-888-PROTHANE).
http://www.prothane.com/Main_Menu/main_menu.html
How are you pulling yours? I have to do mine soon.
Barry
Old Jun 25, 2003 | 06:02 PM
gtex's Avatar
gtex
I thought I'd check here first. As you know, these guys know more than just about anybody out there :-)
I just got the nuts off. I Have nonthing but a rolling chassis, frame and axles. I was thinking of getting a hydraulic jack and some extension wedged in between the tranny x-member and the I beam to push it out.
Do you have any ideas?
The bushings on there look pretty good, it may not be worth the effort.
Old Jun 25, 2003 | 06:31 PM
BB's Avatar
BB
No, I was hoping you had some ideas.
I've thought about the "push the beam out of the way" method but is there that much "give" in the pivot bushings or will those get trashed in the process? Might as well just take the beams off which seems like a lot of work. Only other option is remove the brackets but mine are the original riveted ones and I’d like to keep ‘em that way.
Decisions, decisions…
Old Jun 25, 2003 | 06:35 PM
graymule's Avatar
graymule
i recently bought the prothane total kit for my truck ( from jc whitney also ) everything fit just fine so far, haven't installed the cab bushings yet. there may have been a slight difference in the radius bushings but it all went back together fine. i'm not sure if there's a proper procedure for changing the bushings but i had to remove the entire axle to get them out. i replaced the axle pivot bushings also ( since the axle already out )
it made a big difference in the handling.
mike
Old Jun 25, 2003 | 06:40 PM
sandmanf250's Avatar
sandmanf250
I did the complete prothane kit on my 1970 ranger xlt. What a difference in the handling.Well worth the money and effort
Old Jun 26, 2003 | 01:13 AM
gtex's Avatar
gtex
Are you guys running 1/2 ton trucks? I'm thinking tis kit is not correct for 3/4 Ton trucks or Camper Specials. These bushings look way thin. My current bushings look pretty good, I may just leave them.
Old Jun 26, 2003 | 06:01 AM
sandmanf250
I have a f-100.Probably a big difference with yours
Old Jun 26, 2003 | 09:15 AM
gtex's Avatar
gtex
JC Witney and Prothane market the same kit for F100-F350 trucks. And the individyual package for the bushings even says the same. Something Fishy here. Maybe I'll get some pics later.
Old Jun 27, 2003 | 06:34 PM
willowbilly3's Avatar
willowbilly3
It's not that hard to drop out the whole beam . The only other way is to cut the rivets. You may want to consider a set from a parts store that have the adjustable caster. I think Moog makes them or you can get them from NAPA
Old Jun 27, 2003 | 09:00 PM
Ecuri's Avatar
Ecuri
I just let the suspension fall to full droop and hooked a come-along up from front bumper to axle and slipped it right out. (Rubber hose on threads.)
Didn't seem to hurt a thing.
I am (guessing here) the factory rubber junk compresses a lot more that the "prothane" so they thought of that when they built them. A "before and after" thread count should tell you if you need to have the toe-in reset.
Old Jun 28, 2003 | 03:47 AM
oughtsix's Avatar
oughtsix
I replaced my 67 f-100 front I-beams with I-beams from a 78 f350. The bushings were the same. I would remove the brake caliper / line, remove the lower shock bolt and yank away. I think you may find you will need to have both I-beams pulled forward in order to get the second radius arm out. There is a lot of flex in the I-beam bushings.
Old Jun 28, 2003 | 06:07 AM
notmrbig1's Avatar
notmrbig1
I recently purchased a set of the prothane bushings,but as of yet, I haven't gotten around to putting them in yet. My question to those that have used these bushing is do they squeak like everyone keeps telling me they will?? all I have heard from everyone is that they squeak really loudly and theres nothing I could do to stop it. Any advice would help
Jim
Old Jun 28, 2003 | 06:14 AM
sandmanf250
I've had mine in for a year now and no sqeaks yet.
Old Jun 28, 2003 | 07:52 AM
notmrbig1's Avatar
notmrbig1
Thanks Sandman
Thats good news! how do you like the prothane bushings? did they make a big difference in driving?
jim
