ATF in fuel
Old Jun 25, 2003 | 02:41 PM
Lukkys's Avatar
Lukkys
Question ATF in fuel
Hi,Aguy that had a bunch of school bus with 7.3 was saying that when he had a rough idle or something in one he'd put a quart of ATF in the fuel tank and it would clear most of the problem.He used to put around a million K on them motors.What's your opinion on ATF in fuel.Thanks
Old Jun 25, 2003 | 04:39 PM
cartwright's Avatar
cartwright
ATF in fuel
Its bad. Use Stanadyne performance formula.
Old Jun 26, 2003 | 08:26 PM
walnutcreek's Avatar
walnutcreek
Cool ATF in fuel
Stenadyne is best, I add it at every fuel stop as I don't trust the fuel in my area that much. ATF is meant for a tranny, not a motor in my book anyway, jut my $.02.
Old Jun 26, 2003 | 11:03 PM
french277's Avatar
french277
ATF in fuel
it is really not good idea to use atf because it will change the fuel charticis and the atf is red and if the road inspecter hear that it will wind up with a fine and i will use styane fuel condinter sometime use power service fuel condinter too one of two i can use and i use from time to time to keep my injector tip clean and it dont bother dot regualations
merci marc
Old Jun 29, 2003 | 02:13 PM
argve's Avatar
argve
ATF in fuel
ATF will work, but I would recommend "Fred's Hair Tonic" Stanadyne as it's designed by the same folks that make the fuel system, so they should know what it needs, and it looks nothing like ATF.
Old Jul 15, 2003 | 09:40 PM
larry2000's Avatar
larry2000
ATF in fuel
It is really, really, really N O T a good idea to use atf The inspecter found that my fuel was red and cost me a lot of time and $$$$ to get out of this.
Old Jul 15, 2003 | 09:43 PM
GR8Diesel's Avatar
GR8Diesel
ATF in fuel
larry2000,
How did an inspector get involved with your fuel system?
Old Jul 16, 2003 | 06:42 PM
128racecar's Avatar
128racecar
ATF in fuel
Actually, there is some validity to this question. When I worked for a Mercedes dealer in MN, we made sure every diesel owner had a can of ATF in their trunk in the event they had bad fuel, ie water in it. ATF when added to diesel fuel has water dispersement properties. I added 1 pint to my fuel every oil change (3000 miles) to combat condesation, common in the upper middwest. Worked well in 500, 000 miles of personal use in the 2 MB 240Ds I owned. I don't recall anyone checking fuel for dye traces back then in cars, only semis.
Unrealo4
Feb 24, 2011 09:15 AM
Tym
Sep 22, 2010 10:10 AM
mravetto
Sep 12, 2009 06:54 PM
Reidicus
May 19, 2007 07:13 PM
Smokin'
Jun 21, 2006 01:10 PM
