EASY......RIGHT?
Old Dec 27, 2013 | 04:57 PM
  #31
arctic y block's Avatar
arctic y block
Has he ever said if the indexing plate is there? I wonder?
Old Dec 27, 2013 | 07:54 PM
  #32
ctubutis's Avatar
ctubutis
Probably he doesn't know what an indexing plate is... I'm guessing you're talking about the the thin piece of sheet metal-like substance sandwiched between the engine & transmission?
7007 in the drawing....
Old Dec 28, 2013 | 04:49 AM
  #33
reroy's Avatar
reroy
460 Manual tranny
Yup.. that guy in Minnesota told me over the phone that the bell housing, with manual tranny and hydraulic clutch was a very rare bell housing. Only made 2 years he said.
Is yours a hydraulic clutch ????
LeRoy
Old Dec 28, 2013 | 04:58 AM
  #34
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Leroy,
'83-'97 all had hydraulic clutches.
The later ZF5-speeds had an integral bell.
Those bellhousings were made from '83 until at least '88.
Any 4 speed manual 460 from these years had one.
They may be getting rare now, because many of them have snapped the slave cylinder boss off the outside of the casting.
I know mine did.
I replaced it, and when I switched to a ZF the old one sold within a day of my listing it.
Old Dec 28, 2013 | 01:34 PM
  #35
arctic y block
Yes, I call it that because it indexes the starter. I think Ford has another name for it.
Old Dec 28, 2013 | 01:35 PM
  #36
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1983: E3TZ-7505-B .. 460 Bell Housing - Marked: E3TA-7500-BD
1984/87: E4TZ-7505-B .. 460 Bell Housing (includes E4TZ-7B602-A .. Stud-Clutch Release Lever) - Marked: E4TA-7500-DA or E7TA-7500-BA
Tricky: 7007 = Plate Assy (Engine Rear).
Old Dec 28, 2013 | 03:34 PM
  #37
arctic y block
Thanks Bill
Old Dec 28, 2013 | 08:38 PM
  #38
rowdyredneck's Avatar
rowdyredneck
Over the years I've seen a few Ford engines that would eat starter drives like crazy. An old trick we used to do was to switch to a 10 tooth starter drive. Most Ford drives from that era had 9 teeth, the 10 tooth drive is slightly oversized which would usually solve the problem. Just thought I'd pass that tip along.
NP435Bronco
15
Dec 1, 2025 09:45 AM
crossy
Jan 22, 2017 04:14 PM
4604wd4sp
West Virginia Chapter
Dec 29, 2013 08:47 PM
wizzard351
Apr 19, 2009 11:02 PM
gcfisher75
Nov 23, 2006 11:54 PM
