95 460 shuts down randomly
Old Dec 25, 2013 | 06:22 PM
87diesel's Avatar
87diesel
I have a '95 ford f350 crew cab dually with a 460 in it and dual tanks. We hadn't had any problems until recently when the truck ran cold on a trip. I figured it was the thermostat stuck open so we put cardboard behind the grille to bring it up to temp. Then on the way home the engine shut off. I turned the key off and back on and it started right back up, no check engine light. The next day we drove it again and it did the same thing regardless of what tank was used. I don't know what would cause it. Any advice would help. Thanks.
Old Dec 26, 2013 | 05:08 AM
Necred's Avatar
Necred
I believe theres an issue with the distributor "PIP", you may wanna do a search on it...Most folks have them replaced before 100k...
Old Dec 26, 2013 | 09:35 AM
87diesel's Avatar
87diesel
What does the PIP sensor do?
Old Dec 26, 2013 | 10:01 AM
87diesel's Avatar
87diesel
Another thing i forgot to add was when it died the fuel pump wasn't kicking on until we turned the key to off a couple of times. Then it would work and start right up.
Old Dec 26, 2013 | 04:22 PM
rla2005's Avatar
rla2005
This symptom is classic for a failing computer (PCM) but it could be as simple as a bad Fuel Pump Relay. The fuel pump should kick on for 1-2 seconds when cycling the key from the Off to Run position. You could swap the Fuel Pump relay with the horn relay to test.
If swapping the relays does not help you might want to pull out the PCM, it comes out from the engine side of the firewall, then open it up to look for signs of corrosion, moisture, leaking capacitors or burned components.
Old Dec 26, 2013 | 04:39 PM
87diesel's Avatar
87diesel
where's the fuel pump relay located?
Old Dec 26, 2013 | 04:41 PM
kermmydog's Avatar
kermmydog
I would also check fuel pressures. What about fuel filter. My 95 had 148,000 & the PIP was still fine. Something else on random stuff which can drive a man to drink. Check the top distributor bushing. I had an 86 F250 4x4 460 that drove me to complete insanity. I had a couple of buddies that were good mechanics they messed with it, after about a month of just dying then starting right up again one of my mechanic buddies called me & said bring that truck to my house. Sure enough he pulled the cap & the he could move the shaft enough that every so often the stator would hit the pickup & short out.
Old Dec 26, 2013 | 04:42 PM
rla2005's Avatar
rla2005
From our good friend subford:
Old Dec 26, 2013 | 04:45 PM
87diesel's Avatar
87diesel
alright thanks ill try the relay first
Old Dec 26, 2013 | 04:50 PM
kermmydog's Avatar
kermmydog
All the relays in mine are 7 pin so you can swap any of them around. I doubt that is the issue. It seldom is on Fords. But good to check just the same.
Old Dec 26, 2013 | 05:21 PM
rla2005's Avatar
rla2005
I wanted to start with the simple and easy things first. The relays are not known for going bad, but it is not impossible. I highly suspect the PCM at this point, but never overlook the obvious (and simple/cheap).
Old Jan 3, 2014 | 10:03 AM
87diesel's Avatar
87diesel
The relay didn't work i was going to go to a shop and let them test the computer would that help out?
Old Jan 3, 2014 | 12:51 PM
rla2005's Avatar
rla2005
I did not point out to also check the Fuel Pump fuse "O". The photo I posted before shows it's location. If that fuse is blown there is no power for the fuel pump.
Circuit diagram:
hoss khaos
13
Feb 21, 2016 06:35 PM
tncandleworks
Sep 30, 2012 08:30 AM
jeffrodc
Aug 17, 2010 11:10 PM
zypr
Apr 3, 2003 04:02 PM
