no dash or interior lights
Old Dec 24, 2013 | 06:08 PM
skyway0018746's Avatar
skyway0018746
So I recently picked up a 79 f100 (explorer ) if it matters .went to take her out tonight after doing power brake swap. ( awesome by the way) pulled the light switch .... no dash lights no interior light when turning the switch. So it could possible be the head light switch ?
Something else to add. I don't have turn signals , when installing the brake light switch I found the signal lever will cancel the tail light on the side selected. So this could be un related and could be a flasher relay . But no signal light on dash. It does have an after market radio dont know if anything back there coukd be messed up. So mybquestion is is there anything to check before getting a new switch?
Old Dec 24, 2013 | 06:40 PM
JWC 3's Avatar
JWC 3
fuses good ?
Old Dec 24, 2013 | 06:43 PM
skyway0018746
Haven't checked.... need to get a book .
The alternator light works . It came on when I stalled it .
Old Dec 27, 2013 | 04:44 PM
skyway0018746
update guys got everything worked out I think. the dash light fuse was blown ... hard to find that little 3a fuse had to order one. The signals, ordered a new signal switch. I had hazz but no turn signals didn't even think they had two flasher/relays. went out and sure enough the other one was no good.
Old Dec 28, 2013 | 12:04 AM
JWC 3's Avatar
JWC 3
Glad you got it fixed ! Thanks for posting your fix .
rchawaii
Jun 27, 2019 12:17 AM
dharte
Nov 22, 2014 11:10 PM
LWolffe
Jan 5, 2011 11:40 AM
Waltdog
May 20, 2010 03:17 PM
isaz
Dec 15, 2003 02:28 PM
