One lean cylinder?
Old Dec 24, 2013 | 12:28 PM
Ken Blythen's Avatar
Ken Blythen
One lean cylinder?
Has anyone experienced an intake manifold leak from underneath the manifold?
I have seven tan plugs & one grey (no miss - just the color difference), but no response from starter fluid around the intake.
I'm thinking I might have to lift the intake manifold
Merry Christmas!
Old Dec 24, 2013 | 12:54 PM
ctubutis's Avatar
ctubutis
What happens if you pull the plug wire off that cylinder with the engine idling? Have you done a compression test on that cylinder? Looked under the valve cover? etc.?
Old Dec 24, 2013 | 01:14 PM
Gary Lewis's Avatar
Gary Lewis
Hard to imagine leaking from below, only. Is that plug close to a vacuum tap? EGR?
Old Dec 24, 2013 | 01:34 PM
Ken Blythen
No, I haven't done a compression test on it.
Pulling the plug wire kills that cylinder.....it's not mis-firing at all.
The EGR is gone & plated off (gasket is good); no other vacuum ports close by.
Some extra air is getting to that cylinder somehow.
Old Dec 24, 2013 | 03:21 PM
Gary Lewis's Avatar
Gary Lewis
What about a burned valve? A burned intake on the prior cylinder would upset the charge some as well as decreasing compression. An exhaust valve would just do the latter.
And, by the way, Merry Christmas!
Old Dec 24, 2013 | 03:46 PM
Franklin2's Avatar
Franklin2
I thought a lean burning plug would be white, and possible shiny from it getting very hot.
Old Dec 26, 2013 | 07:14 AM
cadunkle's Avatar
cadunkle
Yes, they can leak from below. I've had trouble sealing my 460, though hads have been shaved. I used the thickest intake gaskets I could find on Summit and sealed alright. Plugs on leaking cylinders looked like burning oil from sucking oil vapor from below.
Old Dec 26, 2013 | 12:55 PM
KsCop's Avatar
KsCop
You could do a leak-down test. If it was a bad intake valve, you'd hear air escaping in the intake. Bad exhaust valve, air into the exhaust, bad head gasket, air or bubbles there
If the leak-down test looks (sounds) OK, I suppose you could have an intake manifold leak..
No functional issues other than the plug color?
Normal plug colors range from grey to light brown (tan) so I'm not sure you even have an issue here.
Maybe I missed it, but is this carburetor or EFI? If EFI, you could easily have an injector that is a little off, but again - runs fine, plugs within the normal range, whats the issue?
Old Dec 26, 2013 | 01:52 PM
Ken Blythen
Carburetor; no symptoms other than the plug color.
The issue is just that seven plugs are identical to each other, but this one alone is different (even with a carb).
You're right that grey isn't radically off on mixture....but something is causing it, & I'm just not happy to work the truck hard knowing one cylinder is burning hotter.
I think this might be it.
Although the one plug is grey now, it has sometimes shown oil.......which I'd previously assumed to be a valve seal because there was no noticeable oil consumption or smoke.
I'll do a compression test anyway to have some numbers, & go from there.
Thanks everyone
Old Dec 26, 2013 | 07:03 PM
cadunkle's Avatar
cadunkle
I also had a leak under the intake on a 454, that one was a torn/shifted gasket and was intermittent noticeable at idle and just off idle. That gasket was installed by previous owner not me, and I know no history of that engine other than it was rebuilt a few years before I got it.
Anyhow, if you don't have any signs of a vacuum leak and just one plug a different color, you may not have a leak. Both leakers I had under the intake were hard to tune at idle/off idle and accelerator pump shot. Plug color will normally vary between the end cylinders and the inner cylinders due to the longer and more complex runners to the corners fuel will drop out of the charge and result in the 4 corners running slightly leaner. Whether this is an issue or how much mixture varies between different cylinders varies based on the particular intake manifold. Jet so your leanest cylinder is where it needs to be.
Old Dec 26, 2013 | 07:29 PM
KsCop's Avatar
KsCop
Maybe it's just me, but no symptoms of a problem, other than one plug that looks different but is still normal; I wouldn't go crazy. It could always be that one plug was a little different from the start. Maybe replace it, run it for a while and see if the 'problem' comes back.
If I had the time, I'd check compression and vacuum, maybe a leak down on that cylinder. If all was within normal range, I'd let well enough be.
That's why normal has a range.
But that's just me. I have enough problems to deal with
Old Dec 27, 2013 | 10:23 PM
Ken Blythen
Well, I've just done a compression test -
1 - 200
2 - 197
3 - 210
4 - 200.......the lean cylinder
5 - 197
6 - 192
7 - 190
8 - 208
I also did a tow yesterday; not heavy, but all hills. Afterwards there were still seven tan plugs, but the 'grey' plug was now snow-white, so I'll definitely lift the intake & look for a leak.
I also remember when I first got the truck, it would occasionally kick back hard on the starter (caused by problems from a bad module connector).
When it did this, the smell of crankcase fumes would waft into the cab, so maybe the intake gasket has been blown from then.
Old Dec 28, 2013 | 07:20 AM
Gary Lewis's Avatar
Gary Lewis
Ken - I used to think compression tests reveal a lot about engines. But I no longer think that as I've had more than one problem a compression test didn't find. One engine had 3 leaking exhaust valves and two leaking intake valves, but the cylinders with the bad valves actually scored high in the compression test. Another engine had a leaking head gasket, but the compression on that cylinder was in the hunt with the others. However, in all cases the leak-down test nailed the problems. So any more I don't bother with the compression test.
In your case if you had a bad valve it might well be missed in the compression test. And, while I can't come up with a good reason for the spark plug color you are getting, I would hate for you to R&R the intake and still have same problem.
Old Dec 28, 2013 | 11:35 AM
Ken Blythen
Thanks Gary. OK, I'll make an air fitting for a leak-down test, & do one next week.
But because of the intermittent oil on this same plug, I tend to think there's a gasket leak under the intake.
Old Dec 28, 2013 | 11:36 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Prior to lifting the intake, try this. Pull and plug the oil cap and PCV. See if the idle changes at all. If the intake has internal leak, there should be signs of vacuum at 1 or both of these locations.
I have seen cases where an intake gasket had a bad spot on the lower portion, allowing air to be sucked from inside the valley. Usually, there were signs of oil on the plug/plugs of the affected cyls, as well as signs of running lean.
