One lean cylinder?
Old Dec 28, 2013 | 11:38 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Originally Posted by Ken Blythen
But because of the intermittent oil on this same plug, I tend to think there's a gasket leak under the intake.
I agree. Oil and lean tend to support the possibility of an intake leak on the lower portion.
Old Dec 28, 2013 | 11:53 AM
Gary Lewis's Avatar
Gary Lewis
Ken - If you don't have a leak-down tester I made one by drilling a .060" hole in a solder-filled fitting. That dimension was found on the internet as being a standard for engines this size. But that made mine very sensitive, and I'm thinking that is due to the sharp entry/exit the drill bit left. I have all the parts to re-work the unit by using a Holley #60 jet, which should not only make it a bit less sensitive but would also make it repeatable.
RW- That's an interesting approach. Presumably you would pull the PVC valve from the valve cover but leave it connected to the vacuum source so the amount of air being introduced doesn't change?
Old Dec 28, 2013 | 11:58 AM
Ken Blythen's Avatar
Ken Blythen
Originally Posted by Rogue_Wulff
Prior to lifting the intake, try this. Pull and plug the oil cap and PCV. See if the idle changes at all. If the intake has internal leak, there should be signs of vacuum at 1 or both of these locations.
Thanks RW, I'll do that; audibly the truck has a good idle, so it's not a huge leak.
There is a small (1/2" mercury), regular flick on the vacuum gauge at idle, which probably makes a leak-down test more valuable to do.
I should have put 2+2 together on all of this earlier.
Old Dec 28, 2013 | 11:59 AM
Ken Blythen
Thanks Gary
Old Dec 28, 2013 | 12:23 PM
Rogue_Wulff
Yeah, intake leaking internally is a bit harder to diagnose, and is easily missed, since you can't see it.
Years ago, I had an FE that had a weak cyl at idle, but over ~1K RPM it ran smoothly. I suspected a burnt valve, but dad wanted to rule out an intake leak before doing a compression test, since it was so much quicker to do. Until that point, I had never even considered the possibility.......
In the end, I was right. But I still learned a valuable lesson from the "master"..... He also told me the smoke was likely from a plugged oil drain in the back of the head. I dunno if I ever told him he was right about that part..... I popped the valve cover off, and oil was pooled at the back, running down the outside as it came off. Piece of wire to clean it out, and it never smoked again.
Old Dec 28, 2013 | 12:27 PM
Gary Lewis's Avatar
Gary Lewis
Pulling the head on a W is easier than the intake on an FE.
Old Dec 28, 2013 | 12:37 PM
Rogue_Wulff
I'd rather pull an entire W, than lift the intake of an FE........ Prolly why that aluminum FE intake is still sitting in the house, and the cast iron one is still on the engine. Only had that aluminum intake for 2.5 years........
Old Aug 20, 2016 | 04:09 AM
Ken Blythen
I fixed this issue a long time ago, but just came across the thread again & realized it was never updated.
For anyone it might help in the future......the problem was one bad valve stem seal, allowing a small trace of oil into that cylinder & causing the plug to burn white without any exhaust smoke.
The oil was also making that cylinder ping at times; the pinging got progressively worse & the exhaust began to smell of oil at an idle.
I replaced all the stem seals while I was in there.....problems over
Old Aug 20, 2016 | 06:44 AM
Gary Lewis's Avatar
Gary Lewis
Thanks for the update, Ken. Glad to know it was that simple.
I wonder what the situation is with Paul's intake. I'll bet he is still running the cast iron one. Man, those FE intakes are massive!
Old Aug 20, 2016 | 10:15 AM
hharris8's Avatar
hharris8
You have got quite a memory to remember to post this. What made you think of it?
Great info by the way.
Old Aug 20, 2016 | 10:38 PM
Ken Blythen
Thanks Gary.
I've never really worked with FE engines; my only experience was removing some broken exhaust manifold studs (bolts?) from a 390 head for a customer once. I did take it for a drive a bit later - torquey!
I accidentally came across it in an unrelated search result. I thought I should follow up
Old Aug 21, 2016 | 07:03 AM
Gary Lewis's Avatar
Gary Lewis
Thanks Gary.
The intake is massive! In fact it is so wide it goes well under the valve covers. When I was about 25 I changed the one on my '72 F250 myself and had no leaks. Looking back on that I'm still amazed I got it done - without a shop crane.
Old Aug 22, 2016 | 09:51 AM
  #28
1986F150six's Avatar
1986F150six
Gary, you were 25!
Old Aug 22, 2016 | 09:52 AM
  #29
Gary Lewis's Avatar
Gary Lewis
Yes, a long, long time ago in an F250 far away.
Old Aug 22, 2016 | 09:58 AM
  #30
1986F150six
If this forum was about sedans, rather than trucks, you could have substituted GALAXIE.
