2003 F550 6.0l Boost Problem
Old Dec 29, 2013 | 09:09 PM
PFD11's Avatar
PFD11
If I may, I'd like to start over.
We are a small VFD with a 2003 F500 6.0. We have had some turbo issues that seem to be resolved and are now dealing with an intake sensor issue. At times, (not always) the truck is very unresponsive for the first 1 to 2 minutes. Once past this point, the truck runs strong with no other issues. The sensor was tracked and appeared to be operating normally.
Has anyone run into this situation before?
Old Dec 29, 2013 | 09:12 PM
Per4mance's Avatar
Per4mance
What do you guys have for monitoring the engine? Anything at all? We need numbers to help you guys out.
Old Dec 29, 2013 | 09:17 PM
Maxium4x4's Avatar
Maxium4x4
You have a few or quite a few sensors, but intake narrows it down. Can you give us the exact description from the paper work the dealer handed you?
Per4mance's Avatar
Per4mance
Up top of this forum there are sticky to help,read all that stuff,it's a big help.A monitor is a must with these engines,you have to know whats going on with the values,because one WILL change the other. I'll bet you have low FICM voltage from the sound of it
Old Dec 29, 2013 | 09:18 PM
PFD11's Avatar
PFD11
Thanks. The truck is attached to a battery charger.
Old Dec 29, 2013 | 09:22 PM
PFD11's Avatar
PFD11
I'll dig out the paperwork for the numbers. Thanks again.
Old Dec 29, 2013 | 09:23 PM
Per4mance's Avatar
Per4mance
How old are the batteries,and have they been load tested individually and the alternator ck 'd for voltage at full load. If it isn't putting out 14.2 with all the gear on it's killing the FICM. Been there and seen it happen.
Maxium4x4's Avatar
Maxium4x4
That would be great.
Old Dec 29, 2013 | 09:27 PM
Maxium4x4's Avatar
Maxium4x4
The truck should have dual alternators.
Old Dec 29, 2013 | 09:29 PM
FordBlueHeart's Avatar
FordBlueHeart
That's a good start PFD. What Per4mance means about a monitor is a device that has specific "guages" or values that will enable both us and you to properly keep an eye on said values. Here at FTE, there are some favorites. Scanguage II, Dashboss for I phone, Torque Pro for Android.
Old Dec 30, 2013 | 03:07 PM
PFD11's Avatar
PFD11
Batteries are 4 yrs old
Here are some volt meter numbers:
off the battery - 12.7v
with the ignition switched on (waiting for glow plugs) - 11.5v
starting - 10.5
idle - 12.0
high idle 12.2
after about 45 seconds the meter jumps to 14.4
We let the truck sit for about 15 minutes and tried it again. Got similar results but reached 14.4v in half the time. Truck is equipped with duel alternators.
Maybe why she stumbles out of the gate??
Old Dec 30, 2013 | 03:12 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Stiction is the likely problem with cold running issues.
Josh
Old Dec 30, 2013 | 03:14 PM
  #28
Maxium4x4's Avatar
Maxium4x4
Describe stumble, when/where/ cold/Hot? Under acceleration at engine temp any? What code or sensor did the Tech write down on your service visit? IAT1 or IAT 2
Old Dec 30, 2013 | 06:06 PM
  #29
Per4mance's Avatar
Per4mance
Does anyone there have a scanner that can read can bus codes? If so get the FICM voltages before start ,at idle,and 2500 RPM there is something def going on here,we'll have you get to the bottom of it !
Old Dec 31, 2013 | 11:11 AM
  #30
PFD11's Avatar
PFD11
Still working on the sensor codes.
The stumbling is an intermittent problem (feels like it running on 5 out of 8). Had one of my members, a Toyota mechanic (I know...I know), attached a remote meter to the charging system and went for a quick ride. The system produced 12.8v for nearly 1 minute yet the truck ran flawlessly from the start.
I'm told that the dual alternator arrangement in the ambulance package (which this has), delays the 2nd by design, but that it can be modified.
I'll be having a face to face with the Ford mechanic today to get the specifics on what he found.
Thanks again for the help
