Help
Old Dec 22, 2013 | 08:55 AM
KristaD2001's Avatar
KristaD2001
Help
What is the normal rpm to run in idle also at 55 for an f-350 power stroke 7.3...seems high. Just replaced the water separator seal, now it's running high and rough.
Old Dec 22, 2013 | 09:08 AM
1996pwrstrk's Avatar
1996pwrstrk
At speed it depends on your gears , what do have for RPM idle?
Old Dec 22, 2013 | 09:13 AM
megawatt00's Avatar
megawatt00
At idle 500 to 1000 RPM depending on if it is cold and the high idle kicks in at 55 that depends on your gearing At 55 MPH you should be under or around1600 to 1800 RPM IIRC
The rough ile you have now is due to air being introduced in the fuel system, that is normal when you replace that seal.
Old Dec 22, 2013 | 09:39 AM
KristaD2001
It's been cold in the morning and has had trouble getting started. Will the air eventually go away?
Old Dec 22, 2013 | 10:01 AM
HKusp's Avatar
HKusp
Yes, if you drive it for about 50 miles, it should smooth out.
Old Dec 22, 2013 | 11:03 AM
timmyboy76's Avatar
timmyboy76
May want to do some ohm testing on glow plugs and test/s on the glow plug relay...last time oil was changed? what weight oil you running?
Old Dec 22, 2013 | 11:38 AM
KristaD2001
Alright, the oil is just due it's over only a couple hundred miles. I went 5000 miles. The oil is 15-40. I was thinking maybe the glow plugs too. it does take it a bit to warm up. I let it run for about 10 minutes. It is just super sensitive on the gas pedal, when it wasn't like that before. That's beside it not wanting to warm up.
Old Dec 22, 2013 | 11:44 AM
Tact's Avatar
Tact
Test your GPR as mentioned above. Switching to synthetic oil helped my romps. Now that I have 30 gallons of Mobil 1 in the garage it looks like I'll be running that for a while.
Old Dec 22, 2013 | 01:32 PM
JOHN2001's Avatar
JOHN2001
Also switch to 5w40 not 15w40 that should help cold starts. Don't be afraid to cycle the glow plugs a couple times. Just because your wait to start light shuts off doesn't mean you have to start cranking. They usually stay on for about 90 seconds to two mins anyways. If you hook up a glow plug led you'll know when they turn on anf shut off.
Old Dec 23, 2013 | 03:01 PM
KristaD2001
Thank you so much for your help and suggestions! I really appreciate it! I will do some Investigating!
Old Dec 23, 2013 | 09:57 PM
BadDogKuzz's Avatar
BadDogKuzz
Since everyone else answered your questions and gave you some great suggestions I'll just say "Welcome to FTE" Stick around it is a great group of people here and they are always willing to help others out.
Old Dec 24, 2013 | 12:07 AM
KristaD2001
I see that! Thank you very much! Greatly appreciating the advice!
LARIAT 85
May 7, 2017 04:17 PM
raven3
5.0L Coyote
Feb 10, 2015 05:35 PM
CA-F250
6.7L Power Stroke Diesel
Nov 18, 2012 07:22 PM
imlowr2
1997 - 2003 F150
Sep 10, 2011 01:51 PM
SBastow
Apr 19, 2008 01:44 AM
