Serial Number Decode
Old Dec 21, 2013 | 11:14 PM
sixtyonef100's Avatar
sixtyonef100
Hi guys I have a 1961 ford f100 unibody and I would like to know more about it. I looked around on the internet but couldn't find anything on how to decode the serial number so here is everything on the data plate.
F1OCK172306
W.B.-122
Color-B
Model-F100
Max G.V.W.-5000
Trans-F
Axle- 11
D.S.O-5932
Cert. Net H.P.-135 @3800 rpm
Old Dec 21, 2013 | 11:23 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I looked around on the internet but couldn't find anything on how to decode the serial number so here is everything on the warranty plate.
VIN: F10CK172306 / W.B.-122 / Color-B / Model-F100 / Trans-F / Axle-11 / MAX GVW LBS-5000 / Cert. Net H.P.-135 / RPM-3800 / DSO-5932
Codes rearranged to their sequence as listed on the Warranty Plate.
F10 = F100 2WD
C = 292 2V
K = Kansas City MO Assembly Plant.
172306 = 1961, assembled May 1961.
122" Wheelbase.
B = Caribbean Turquoise.
F100 2WD, 5,000 lbs. GVWR
F = Borg Warner T-98 4 Speed Manual Transmission.
11 = Ford 9" Rear Axle / 3.70-1 / No Limited Slip / 3,300 lbs. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
135 net HP @ 3,800 RPM
5932 = Domestic Special Order number, truck was ordered special by original purchaser, not "bought off the lot."
Old Dec 21, 2013 | 11:33 PM
sixtyonef100
Thank you very much for the quick reply I really appreciate it.
Pireaux
Jul 19, 2014 12:08 PM
Pacecar1986
Jul 17, 2014 08:18 PM
kwlowe
May 4, 2009 09:33 AM
Shorty 66
Mar 23, 2009 01:21 AM
dullchrome
Jan 27, 2009 11:11 AM
