after my last cam failed I decided to almost completely rebuild my motor I got a Lunati bracket master 2 cam and lifter kit, comp cams high energy push rods triple valve springs retainers and 10 degree four groove valve locks, edelbrock performer intake, holley 750 double pumper, summit headers, I had the valves cleaned and bosses milled down for comp cams roller rockers and ARP studs. using stock size valves. I got a re ring kit and crank re ground with new bearings. im going to get the msd street fire ignition box, steel spool, 3.89 gears and a 3300 stall torque converter. When I first run the motor to break in everything, do I need to take out the inner valve springs? and what kind of power should I be making? thanks.
after my last cam failed I decided to almost completely rebuild my motor I got a Lunati bracket master 2 cam and lifter kit, comp cams high energy push rods triple valve springs retainers and 10 degree four groove valve locks, edelbrock performer intake, holley 750 doublepumper, summit headers, I had the valves
Try to get the single valve groove type and one piece. Better grip than multi-groove.what kind of pistons are you using?
the springs are the lower pressure 924-16 if I remember correctly I got the ones my instructor told me to- I'm in auto mechanics at my local community college. the pistons are hypereutectic. the rods I'm not sure. they came with the pistons. stock heads with the mentioned work. block is bored 30 over.
. That 224/234 cam Lunati is actually fairly big for truck use, lopey idle, will start pulling hard around 2500-3000 RPMs... pull strong beyond 6000 RPMs with 11.5-12.5:1 compression ratio and big enough head ports/valves...
. I have a 224/234 Summit cam for a SBC 405" engine w/ MoTown heads I'm building for car usage...
I like my bracket master. has 112 LSA and 300 or 310 duration. I forgot. good lope with some glass packs. I can't wait to get it going. I'll have headers with cutouts. I'll be the annoying guy down the road. lol
