Coolant filter install.
Old Dec 21, 2013 | 02:13 PM
Hotwheelbill's Avatar
Hotwheelbill
I picked up a kit on ebay with three Baldwin 5134 filters. Good price but no instructions. I can see that it will bolt onto the fan shroud support, but not sure where to tap into for 1) into filter. Can I just tap into the water pump like I did my 7.3? 2) Best place to let it back in the system?
Old Dec 21, 2013 | 02:50 PM
Corner Gas's Avatar
Corner Gas
I hope this picture helps. The input line tees into the line from the degas bottle to the rad and the other line tees into the line going to the heater core.
Old Dec 21, 2013 | 03:13 PM
Sark's Avatar
Sark
Thumbs up
I installed the Dfuser Coolant Kit & here's a link to the installation instructions:
http://www.dfuser.com/Install%20Guid...filter_kit.pdf
Good luck!
Old Dec 21, 2013 | 03:48 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Here's a overall view of my Sininster install. The hose going to the rear by the heater box is however incorrect.
This is where origonally put the larger "T" fitting.
Turns out if your truck has the vacume operated heater control valve (depends on model) the "T" should be installed BEFORE the valve, toward the front of the engine like this.
Also, I like these style clamps. The sell them for fuel lines on TBI equipped vehicles.
The bracket for the filter base just bolted up over this radiator mount stud. Yours may be different.
Pretty simple install. Maybe 30min. Be sure to lube the seal on the filter so it will come off next time without bending the mount. A little motor oil, Vaseline, whatever will be fine.
Good luck!
Old Dec 21, 2013 | 03:54 PM
Rusty Axlerod
Also, when it comes time to buy more filters, any of these will fit. Remember to NOT get filter pre-charged with SCA (Supplemental Coolant Additive) unless the coolant you're using specifies it. Many filters fit this base AND contain SCA. None of the filters on this list are "pre-charged"
Fleetguard WF-2077
Baldwin B5134
Baldwin B5089 (shorter)
John Deere RE11992
Caterpillar 9Y4528
Cummins 3300721
Wix 24070
NAPA 4070
NAPA 4069 (one inch shorter)
AC-Delco WF-108
Fram PR3383
Donaldson P554685
Alliance (Freightliner) WF2077
CarQuest 89070
Hasting WC8
Purolator W54451
Old Dec 21, 2013 | 04:24 PM
r2millers's Avatar
r2millers
I'm confused by your comment above.
Just to avoid a mistake, The input line to the filter comes from the heater hose, the return line goes up to the degas bottle.
I'm not sure that was clear.
Old Dec 21, 2013 | 05:19 PM
Corner Gas's Avatar
Corner Gas
Thanks for catching that, you are right.
Old Dec 22, 2013 | 05:40 AM
Hotwheelbill
Got it. Thanks guys.
I plan to install on my last flush in a couple days.
2500ak
18
Oct 30, 2013 01:25 AM
Ryandee18
Oct 10, 2013 10:37 PM
havns3
Aug 29, 2010 09:24 AM
WishIhada7.3
Mar 22, 2009 09:45 PM
F0rdF0rever
Mar 19, 2008 05:25 PM
