ICP Readings
Old Dec 21, 2013 | 09:23 AM
Stealth94rttt's Avatar
Stealth94rttt
ICP Readings
I have heard that an ICP > 600 is required to start the engine. I was wondering what the ICP limit is for the engine to stop running.
At idle I am a 640 +/- 2psi but on a coast down (no throttle coming to a stop light) I have seen downwards of 595 psi for a reading or two (using Torque to monitor). Is this something to be concerned about? I just did am oil change yesterday with motorcraft oils and filters and still see the same readings so it seems to be independent of oil age.
Old Dec 21, 2013 | 09:27 AM
npccpartsman's Avatar
npccpartsman
Actually it's >500 to start. Mine idles at 585 all the time. You're fine.
Old Dec 21, 2013 | 09:45 AM
Green96's Avatar
Green96
I seen on something that someone posted here that 625 was desired. Mine is like yours as it idles at about 585. Glad to see that this is normal. I love this truck and this engine but sometimes paranoia gets the best of you. To the OP, sorry for the HiJack.
Old Dec 21, 2013 | 09:59 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Early 6.0 ICP desired is slightly higher than the later 6.0 engines, 620 vs 580.
Most scanners only see ICP desired versus ICP actual which is based off the ICP volts.
Josh
Old Dec 21, 2013 | 10:03 AM
Green96's Avatar
Green96
Josh
That makes sense. My truck is a 2006. Thanks for the input.
302flareside1992
Apr 3, 2016 11:09 AM
makuloco2000
Nov 5, 2014 10:57 PM
mahd776
Feb 1, 2014 08:53 AM
mahd776
Jan 30, 2014 06:20 AM
nut1605
Nov 10, 2013 10:03 AM
