Gutless now
Old Dec 21, 2013 | 08:13 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Not that I "got away with it"
Look at Summit's application page and recommended parts.
Look at the dozens of threads about this kit.
I would not suggest the use of stock springs with the 3501 cam.
Originally Posted by FlyTyingGuy-asked
My question is those people that are running a summit racing 3500 cam...
If he wants to know what my personal experience is with the cam he has just installed I am willing to answer his question from the perspective of someone who had one installed in my truck for over a decade.
Old Dec 23, 2013 | 08:59 AM
fly-tying.guy's Avatar
fly-tying.guy
So my ignition is set to 8 degrees before tdc and with the advance on its at about 6 degrees. I was just wanting to ask say by accident I got my distributor 180 degrees off would my truck still run when it is revved up. The only reson I am asking is because my truck won't even start without my foot to the floor and won't try to idle but shows the timing is on would this cause the problems I am looking at
Old Dec 23, 2013 | 09:15 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You say static timing is 8* BTDC and you have already checked that the marks on the damper line up at 0* with TDC#1 on compression.
The rotor can only go on the distributor shaft one way.
I don't understand what you mean "with the advance on its at about 6 degrees"
The vacuum advance only adds timing to the existing static setting (and any centrifugal advance - that should come in between 900 and 3000 rpm)
Old Dec 23, 2013 | 11:43 AM
Franklin2's Avatar
Franklin2
It won't even start if it was 180 off. Loosen the dist so you can just barely turn it with some force, get someone to get the engine running, and then twist the dist to see if you can get it to run better by ear. You have nothing to lose.
Nathan Vos
Apr 29, 2017 02:20 PM
Tnewton
Mar 8, 2016 05:13 PM
mustang_gt_350
Mar 4, 2011 07:54 AM
rdw516
May 30, 2006 08:49 PM
dpoelstra
Aug 31, 2002 12:28 AM
