Sponsored by: Real Truck
What brake controller and harness?
Old Dec 20, 2013 | 06:21 PM
kickstand03263's Avatar
kickstand03263
What brake controller and harness should I get for my 2000 f250 super duty?
Old Dec 20, 2013 | 06:54 PM
Super Duty Diablo's Avatar
Super Duty Diablo
I have the Tekonsha Prodigy with a Ford plug and play harness.
Brake Controllers - Tekonsha
Old Dec 20, 2013 | 06:58 PM
jswartz84's Avatar
jswartz84
X2 on the Tekonsha Prodigy
Old Dec 21, 2013 | 06:47 AM
kickstand03263
Is there a big difference between the Prodigy P2 and P3? Do you have a part number on the ford harness?
Old Dec 21, 2013 | 08:21 AM
JohnnyThunder's Avatar
JohnnyThunder
The P3 is for 3 axles and the P2 for 2. They use the same harness. I would recommend the P3, I had one for years and it is an amazing controller. I would say it is as close to the newer factory Ford unit as you will ever find. The new ones even have memory like the factory Ford ones for different trailers.
Old Dec 21, 2013 | 11:24 AM
bryan_ore's Avatar
bryan_ore
Just a quick note on the Tekonsha and harness... if you do go with the Tekonsha controller, they make a direct plug and play harness. It plugs into the truck on one end and the controller on the other. No cutting or splicing. I used one on the 99 I had before I moved to the 06 that has the integrated. It worked great. You can pick one up for $10.
Old Dec 21, 2013 | 02:35 PM
Army RET's Avatar
Army RET
I went with the P2 because I know me, I'd be playing around with all the extra graphics on the P3; I didn't need more distracted driving.
Note: my Tek plug and play harness cost $18 because I needed it now (Camper World price).
Old Dec 22, 2013 | 05:31 PM
Prozon's Avatar
Prozon
I have the Prodigy P2 in my truck. I bought a harness off eBay for like $8, I just had to connect the wiring. As Bryan Ore mentioned- you can buy the one for the controller directly so you can just plug it in. (For like $10-12.)
Old Dec 22, 2013 | 08:37 PM
kickstand03263
You guys rock, thank you for all the info!
Old Dec 24, 2013 | 06:54 PM
Delawhere?'s Avatar
Delawhere?
I had the Prodigy P2 also and it was an excellent brake controller, just upgraded to a 2014 SD and now have the OEM Ford controller. So far it has worked like it's supposed to but I did like the prodigy and the digital readout. It let you know what you were running and whether you needed more was just a turn of the dial.
Magnolia Tom
All Other Items for Sale
Nov 29, 2015 06:54 PM
kdwellssr
1997 - 2003 F150
Jul 18, 2015 09:08 AM
kickstand03263
All Things Towing
Feb 7, 2013 12:40 PM
ericcoplan
Apr 29, 2011 12:07 PM
jimmy4321
Mar 17, 2011 12:29 PM
