door panel back pad
Old Dec 20, 2013 | 11:08 AM
V10man's Avatar
V10man
door panel back pad
I need to replace the fibrous pad that goes between the metal door and the door panel. I have an old one I can use for a pattern. What have you all used for this? I was gonna look at the carpet pad at Home Depot. Any other ideas? I would like the panel tight and solid so it wont rattle with the speakers. btw, my panels are aftermarket, el cheepie one piece that used to use push pins to hold it on. I have replaced the pins with screws for easier access.
Old Dec 20, 2013 | 11:58 AM
84espy's Avatar
84espy
I used carpet pad also for a firmer fit. You may have to put sound deadener inside the door to eliminate all the speaker/door rattle, though.
Old Dec 20, 2013 | 02:30 PM
ArcadeTom's Avatar
ArcadeTom
The door insulation between the panel and door will need to be designed for getting wet and dried out or it will stink after the first car wash or rain storm.
If you look trhough some of the vendors here as well as LMC, you can buy them precut and made from the correct material so you don't have that problem. Been there, done that...
GeneGregory
Jul 12, 2015 07:46 PM
99expy
Apr 9, 2010 01:30 PM
Pud12343
Aug 18, 2007 12:31 AM
RoyalFord
Mar 19, 2005 02:33 PM
sacky07
Feb 8, 2005 07:33 PM
