SYNC compatibility w/iphone 5s?
Old Jan 3, 2014 | 09:12 AM
  #31
FordIVTteam's Avatar
FordIVTteam
Official Ford Rep
Originally Posted by lwk362393
I have v3.1, and the SyncMyRide website says that's the most up-to-date version. Should I be seeing that menu option? I've gone through every menu possible since I've had the truck and have never seen it.
lwk362393,
Were you able to locate the menu option using BlackBeest's guide? PM your VIN if you're still unable to find the MAP Profile option and I'll verify your software level.
Antonio
Old Jan 3, 2014 | 06:35 PM
  #32
bironacad's Avatar
bironacad
Excellent, BB, thanks, I will have to keep this as a book mark
Old Jan 3, 2014 | 09:05 PM
  #33
lwk362393's Avatar
lwk362393
Originally Posted by BlackBeest
That's as far as I've got, hope it helps
Thanks BlackBeest, but I didn't get very far. I wasn't even able to turn on the text message notification setting. Below are some pictures of what my menus look like.
<a href="http://www.flickr.com/photos/113366809@N03/11743676524/" title="Truck text message menus by lwk362393, on Flickr"><img src="http://farm4.staticflickr.com/3750/11743676524_441a2445f5.jpg" width="500" height="375" alt="Truck text message menus"></a>
The message I get when I try to turn on text notifications…
<a href="http://www.flickr.com/photos/113366809@N03/11743515953/" title="Truck text message menus by lwk362393, on Flickr"><img src="http://farm8.staticflickr.com/7344/11743515953_fa0da73a31.jpg" width="500" height="375" alt="Truck text message menus"></a>
The other two pages of phone settings
<a href="http://www.flickr.com/photos/113366809@N03/11743264545/" title="Truck text message menus by lwk362393, on Flickr"><img src="http://farm3.staticflickr.com/2872/11743264545_51c48b6507.jpg" width="500" height="375" alt="Truck text message menus"></a>
<a href="http://www.flickr.com/photos/113366809@N03/11744014346/" title="Truck text message menus by lwk362393, on Flickr"><img src="http://farm4.staticflickr.com/3702/11744014346_64bee6072f.jpg" width="500" height="375" alt="Truck text message menus"></a>
lwk362393,
Antonio
PM sent Antonio, thanks!
Old Jan 3, 2014 | 11:24 PM
  #34
F16Vip3r's Avatar
F16Vip3r
Similar issues
I've also got an update along these same lines:
After double checking what Antonio advised trying, my truck now also reads my iphone 4s texts to me, after notifying a new message has arrived!!
But not everything is gravy, for some weird reason, it always shows the contact as UNKNOWN even they they're coming from contacts in my phonebook
So I can't reply to them. A step further, I now get "message sent successfully" pop-ups when I choose a contact in my phonebook and send them one of those generic "call me" messages, but they never receive it
EO- are you able to reply to those texts? And your contact comes up correctly?
I've got a 2013 F-350 w/ MyFordTouch, and I'm seeing similar (yet different) issues. It tells me WHO sent the message, and reads them fine, but I don't seem to be able to reply. I can go in, find the 15 generic replies, but the 6-9 times I tried to send the messages, it kept failing.
Not a huge deal, since I don't plan on using the capability much, but I'm continuing to follow this thread in case someone figures it out.
Old Jan 5, 2014 | 01:00 PM
  #35
'12 Duty Super's Avatar
'12 Duty Super
I'm having the same problem as BlackBeest and not seeing who it was from with my iPhone 5s. Like his everything seems to be fine but it doesn't show who sent it. Also when I try and download my messages into sync it says download fail or something like that. Is there a setting on my 5s that's preventing sync from talking to my phone completely?
Old Jan 9, 2014 | 03:01 PM
  #36
FordIVTteam
Official Ford Rep
Hi F16Vip3r,
It seems like the MFT system is able to access and interpret messages with with the iPhone, but the iOS firmware doesn't let SYNC's commands go through - therefore sent messages aren't successful. This is a behavior we're currently monitoring and seems to be the case across the board. I'll spread the word if anything changes with the next iOS release or some sort of workaround is developed.
Hi '12 Duty Super,
The best thing to do when your texting functionality is partial is to ensure your phone has the strongest possible connection with SYNC. There aren't any settings to change that would directly effect this, other than verifying that the Notifications preference in your iPhone Bluetooth menu are enabled. Try performing a clean pairing by removing SYNC from your phone, then removing the phone from SYNC, then reconnecting. You could soft reset the iPhone by holding down the home button and the power button down for about 9 seconds until Apple logo appears. These measures will ensure your phone has the strongest signal, therefore clearest channel, to communicate with SYNC.
As I mentioned above, partial texting capabilities seem to be commonplace among iPhones these days - which is still progress, considering the devices never worked to begin with upon initial release. My team will continue to track any trends and movements among other users in hopes of developing a means to get the iPhone working reliably with this feature.
Antonio
Old Jan 9, 2014 | 08:51 PM
  #37
F16Vip3r's Avatar
F16Vip3r
Originally Posted by FordIVTteam
Hi F16Vip3r, It seems like the MFT system is able to access and interpret messages with with the iPhone, but the iOS firmware doesn't let SYNC's commands go through - therefore sent messages aren't successful. This is a behavior we're currently monitoring and seems to be the case across the board. I'll spread the word if anything changes with the next iOS release or some sort of workaround is developed. Antonio
Thanks Antonio! I appreciate the response, and the fact that Ford takes the time to monitor these forums.
-Matt
Old Jan 9, 2014 | 08:56 PM
  #38
'12 Duty Super
Thanks Antonio I'll give it a try. Ditto what F16Vip3r said as well!!!
Old Mar 10, 2014 | 05:21 PM
  #39
bironacad's Avatar
bironacad
Originally Posted by bironacad
Wait this says we can
http://support.ford.com/sync-technol...touchAttention, iPhone users! We’re happy to announce that SYNC can now read your text messages aloud to you while you're driving. Please note, to use this feature you must be running your SYNC with MyFord Touch system on software version 3.5.
If your iPhone is running a more recent version of iOS 6 (e.g., 6.1.3), it may support this new text messaging capability without requiring much set-up effort. First, follow the steps below to see if your iPhone can work with SYNC to read your text messages aloud.
- See more at: How to allow SYNC to receive text messages from your iPhone | MyFord Touch | Ford.com
Picked up my truck today ;-) following these instructions was able to recieve texts and listen to them using voice command however I was not able to send a text using voice command am I missing something?
Old Mar 11, 2014 | 09:14 AM
  #40
FordIVTteam
Official Ford Rep
Hi bironacad,
I can shed some light on this one. The workarounds currently in place allow for the iPhones to share partial functionality with the texting feature, but as it currently stands it doesn't seem they offer consistent performance when sending text messages. This is subject to change with the release of the next iOS version, but we'll have to wait and see.
Antonio
Old Mar 11, 2014 | 10:20 AM
  #41
lundman's Avatar
lundman
i-phones
I have an i-phone 4 for personal use and I have an i-phone 5 for business. Both hook up better to sync than my previous Samsung which was an older model.
However, I don't use the text features when driving. Although it could be useful.
My problem with the i-phone is more with Apple. The battery can not be disconnected by the user and whether the i-phone is off or on, Apple tracks where you are and sells it to business to track your habits. Something I strongly feel against. For this reason I will opt out of the i-phones until they change their policy. I have nothing to hide but don't like "Big Brother" snooping where it has no right to.
Old Mar 11, 2014 | 11:40 AM
  #42
bironacad's Avatar
bironacad
Hi bironacad,
Antonio
Thanks I have been considering buying a samsung but will hold onto my $400 and wait see
Lol
Old Mar 18, 2014 | 04:47 PM
  #43
bnmccoy's Avatar
bnmccoy
The Sync website says I have current update:
CR3T-14D544-AC; version GEN1-V4.0.2
this is what the truck was built with; I can't enable the text messaging for my new iPhone.
I have a subscription to motorcraftservice.com and it looks to me as if Gen1 - 4.2.1.4 is available and lists the following enhancements:
- Updated Bluetooth device connectivity
- Improved system stability
- Improved media player functionality
- Enhanced voice recognition capabilities
- Optimized for use with Apple iOS 6 for incoming text messaging
This update includes improvements from all previous SYNC updates such as flattened phone grammar, improvements in device indexing, text messaging capabilities with the implementation of message access profile (MAP), and more. For additional information on previous updates, visit SYNCmyride.com.
SYNCmyride.com will not offer me any update; how can I update my truck?
PM left for Antonio with my VIN......
TNX
Bob
Old Mar 18, 2014 | 05:12 PM
  #44
BlackBeest's Avatar
BlackBeest
Wow.... 4.2.1.4?
I thought my 3.2.5 was the "newest"!
Syncmyride also didn't show an update available for my truck, Bob, but I called the customer service and was given that there was in fact an update available, so I swung by the local dealer and told 'em to update it.
They did, but there's been a glitch ever since, I've been trying to find time and info to get it back to 'em, and like you, I can't download the update from syncmyride because it shows my truck up to date.
But if you call 'em you might be told something different, I took that info to my dealer and said "do it" and they were able to.
Long gone are the days when the dealer was the be-all end-all source of info for that given vehicle, and I'm not knocking 'em, it's just, the technology age.... we can gain access to info they may not know about unless we shine the light on it for 'em.
But I've about had it with my current SYNC glitch, so I lit a fire under 'em earlier today, hopefully I'll have some better news in a few days
Old Mar 19, 2014 | 05:27 PM
  #45
bnmccoy's Avatar
bnmccoy
There is an old TSB out there that says to have it updated if it sometimes doesn't respond to voice commands; mine does that on occasion, but never if you're trying to get it to mess up.
No reply back on the PM to Ford that I left; maybe on vacation this week.
I will ultimately go to dealer if I can't get an upgrade over the internet to a USB stick.
Good luck with your issues.
Bob
