6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
high boost at low rpms?????
Old Dec 19, 2013 | 07:26 PM
665 Almostevil's Avatar
665 Almostevil
I have a 08 6.4 f250 stock with 96k when I drive the truck for over an hour the turbo starts to make high boost at low rpms like the actuator is stuck or the vains are bad. Also it stays high three or four seconds after you let off the throttle then their is a wub wub wub sound of all the turbo pressure going who knows where . Has anyone else had this problem?
Old Dec 19, 2013 | 07:51 PM
Tom's Avatar
Tom
Hi Almostevil, welcome to FTE!
I'm going to move this one down to the 6.4L forum, most of those knowledgeable on the 6.4L engine can be found down there.
Old Dec 20, 2013 | 12:12 PM
665 Almostevil
thanks tom.
Old Jan 1, 2014 | 08:21 PM
665 Almostevil
no luck still on this problem i am wondering if it fixable or will i most likely need a new turbo or actuator
F3502015
6.7L Power Stroke Diesel
Apr 14, 2016 10:49 AM
MAD
Nov 27, 2013 03:45 PM
jacklaw
Aug 2, 2011 02:19 PM
Firemedic61
May 26, 2006 07:05 AM
