3G alternator swap problem
Old Dec 20, 2013 | 11:47 AM
Gary Lewis's Avatar
Gary Lewis
Not really. Ford used really small wire and there is a significant voltage drop inside the cab. That's why I asked your only reliable way to find out if the alternator is working right is to test at the solenoid. If that is good and you want to chase the voltage drop to the inside of the cab then proceed from there. But one thing at a time.
Old Dec 20, 2013 | 12:11 PM
Filko's Avatar
Filko
Maybe something is wrong with the fan, because only then voltage drops and I don't think that fan consumption is so high or is it?
I must check for the ground of the fan and cabin.
Old Dec 20, 2013 | 12:13 PM
Gary Lewis's Avatar
Gary Lewis
Further to that, there are known voltage drops in these trucks when the connections are perfect, meaning new. The headlight switch and associated wiring, and the ignition switch and associated wiring. Both are known to show a significant voltage drop when the headlights and fan are on full. And then there is the cab ground, which is frequently left off when engine work is done. For all of those reasons you must check the alternator's output voltage at the solenoid, not inside.
Old Dec 20, 2013 | 12:14 PM
Gary Lewis's Avatar
Gary Lewis
Look at the fuse on the fan - it can pull close to that. And if the ground is bad your cab voltage will be awful. One step at a time.
Old Dec 20, 2013 | 08:58 PM
Franklin2's Avatar
Franklin2
The yellow wire goes into the cab. Some of the trucks had two yellow wires, one goes to the ignition switch and ones goes to the fuse box. But some only had 1 wire, and there is a splice under the dash where it splits and goes to the ignition switch and the fuse box.
What I would do is get everything going with the fan on high, and take a measurement at the fuse box. If it's low, then you know the problem is with the yellow wire somewhere.
But, I am with some of the others in this thread, I bet you do not have a problem, it's just the way it is on these trucks. If you want to beef up the wiring go ahead. But you are not going to be able to shove 200 amps into the original truck's wiring. Most people who buy these large alternators buy them for some other reason, and add little aux fuse boxes under the hood to distribute the power to their added power hogs, and leave the stock wiring alone.
You will never be able to realize the full output of this 200 amp alternator anyway of you are only running the stock single groove v-belt. It's a little thing that the people that sell these alternators just happen not to tell you about.
Old Dec 20, 2013 | 09:58 PM
Gary Lewis's Avatar
Gary Lewis
Yep. Testing has shown a single V-belt good for 95 amps, after which it slips. Which is why I plan on running two belts to my 3G alternator.
The two main power hogs on a stock vehicle are the headlights and the HVAC fan. In the resto mod on Dad's truck I will be installing a fuse/relay box like Dave was talking about. And in the box I'll run relays for the headlights and the fan. That way the itty bitty wires and 33 year old switches will only have to source enough current to pull the relays in and the heavy current will be sourced by my new, heavy-duty wiring.
Andy_F100
Electrical Systems/Wiring
May 13, 2018 12:28 PM
RANGER589
May 20, 2011 08:40 AM
79FordBlake
Jan 24, 2010 11:55 AM
grover
Nov 4, 2005 11:41 AM
carlo
Dec 31, 2004 12:35 AM
