Charging problem Surprise
Old Dec 29, 2004 | 10:12 PM
carlo's Avatar
carlo
Background info: 70 351 Cleveland in a Mustang. Stock alternator just not enough amps and replaced for higher amperage unit. Regulator replaced at same time.
100 amp unit was dropped in today, and it's not charging. It's possible that it momentarily charged which makes me question if it was the regulator blowing due to the high amp rating of this alternator? I'd like to know if there is a way to test the alternator while on the vehicle wihtout any special equipment. I was contemplating give the field terminal 12 volts, but they was afraid I could make matters worse
THANKS A lot guys. I know you always are on top of things. Sorry I sold my truck and went to the dark side, but I needed a family vehicle and the Mustang is just my baby on the side.
Old Dec 30, 2004 | 09:03 AM
jtmerritt's Avatar
jtmerritt
Amperage of the alternator does not effect the regulator's ability to manage charging. Is the wiring for the circuit from the alternator to the regulator supposed to be the same for both alternators? Are you sure the 100 amp doesn't have an internal regulator? Are you sure the alternator is good? Sorry if these seem like dumb ?s but I have seen the internal regulator problem on another alternator swap. Also, if the wiring from the alternator to the regulator isn't the same this could definitely be your problem. Used to be you could stick a screwdriver into a test slot on the alternator to verify the alternator was charging.
John
Old Dec 31, 2004 | 12:35 AM
carlo's Avatar
carlo
Thanks John.
I got it all worked out as this morning I used a + lead to quickly test if the alternator was good. I then tested the F output on the regulator and it was dead. Got a new regulator and voila...charging.
