'89 F250 dual tanks cross feeding
11-18-2015, 01:24 PM
Quote:
Originally Posted by
ArdWrknTrk
Didn't Ford issue a bandaid repair for this by installing check valves external to the tanks?
Not for this system with the HP pump on the frame.
Besides the check valves were for the pressure lines only and not the return lines.
11-18-2015, 01:35 PM
Gotcha, thank you!
So that was for models with the HP fuel delivery modules in the tank and no valve on the frame.
11-18-2015, 02:00 PM
on
If it is truly the return fuel being misdirected to the front tank (whjen the rear tank is chosen) external check valves would not help
Riley.Greenup
08-02-2019 12:53 PM
V8SHO
19
04-24-2017 05:36 PM
turbosporsche
10-26-2015 08:05 PM
smsperformance
12-05-2009 04:12 PM
subford
04-11-2006 10:57 PM
