Truck only blows on defrost
My truck only shoots air out of the defroster and only on fan speed 4. I know the fan speed issue is due to a bad resistor.
The previous owner put a new fender on it and said he "forgot to hook up a vacuum line behind it" that controls the directional movement of the air flow.
I looked at the vacuum line under the dash and it seemed fine as did the one near the blower motor under the hood.
What am I missing?
Thanks,
What am I missing?
Thanks,
There's only 1 vac line from the engine to the HVAC controls and it ain't supposed to be behind a fender. Should be over there near the heater box on the passenger side of the engine bay. Supposed to have a check valve in it too I think. If that line is connected, you should have vac at the mode selector in the cab.
AC Vacuum tank:
Vacuum line and check valve:
Vacuum source:
Tailgate77478
06-19-2011 09:07 AM
thordehr
05-11-2010 12:31 PM
johnfl
02-19-2010 08:35 AM
