Sponsored by: Auxito
No turn signals
Old Jun 17, 2004 | 07:46 AM
blackeye's Avatar
blackeye
No turn signals
on front of truck, so I replaced the bulbs. Still no front turn signals, the rear work fine. I have come to the conclusion that the multi function switch is the culprit. Oooorrrrr should I be looking at something else?
TIA
Old Jun 17, 2004 | 12:55 PM
ranger88a's Avatar
ranger88a
It probably is the switch.
Old Jun 17, 2004 | 04:36 PM
bosshoss's Avatar
bosshoss
Does the emergncy flashers work, if not will they work by playing with the switch?
I would suspect a bad MFS.
Old Jun 25, 2004 | 11:43 PM
blackeye's Avatar
blackeye
Well I got time to install the new MFS and guess what that wasnt the problem. There are two plastic wire retainers that plug into the MFS and the wires were a little short on the upper one.
So every time the wheel was in tilt position it pulled on the wires breaking the little plastic retaining clips. $5.83 later we are fixed.
Old Jun 25, 2004 | 11:50 PM
Racerguy's Avatar
Racerguy
Thanks for letting us know what you found
