anything needed w/mechanical gauges?
Old Dec 17, 2013 | 10:34 AM
minnesota-clint's Avatar
minnesota-clint
I was having issues with charging(batt. lite version). So I picked up a new/used instrument cluster (w/tach...woohoo) andwireharness.
Is there anything I will need to do whither having all "needle gauges" instead of the 2 lights?
Old Dec 17, 2013 | 11:38 AM
Franklin2's Avatar
Franklin2
It depends on what year truck you have.
Edit; You will have to do some re-wiring for the alternator also.
Old Dec 19, 2013 | 09:11 AM
minnesota-clint
I have 84 f150 (built in canada. Has a 83 wiring layout), I6 (dsII conversion).
I had fuse box, charging(battle.light), issues and no tach.
I picked up wireharness, cluster w/tach from (I think) 81 f250, V8, I think 4x4.
There are about 4-5 spots on the harness that are different.
Any advise as I jump into trying to wire "old" plug onto "new" harness?
Old Dec 20, 2013 | 08:55 AM
Franklin2's Avatar
Franklin2
You need the complete engine harness, I do not know if the v8 harness will work with the 6 though. Where the problem lies is the charging circuit, your alternator needs the idiot light in the old cluster to charge.
You need the sending units for the gauges also.
ranger332
16
Mar 18, 2022 05:19 PM
minnesota-clint
Jan 10, 2014 05:16 AM
BigB9000
Dec 29, 2012 02:37 PM
Ranger80
Nov 29, 2011 09:16 AM
mudder460
Oct 25, 2010 06:14 PM
