Cluster swap wiring question
Old Oct 24, 2010 | 08:54 PM
mudder460's Avatar
mudder460
I just got a new cluster from a friend and it has all the gauges in it. The one I have now only has 2 in there. I am trying to figure out how to wire everything up now. I have the harness for the new cluster. I am just concerned how to wire the 2 new gauges.
Old Oct 24, 2010 | 09:25 PM
4x4 Bart's Avatar
4x4 Bart
You MUST also swap out the short harness to the alternator or the gauges won't work. The alternator harness is different from lights to gauges.
You can check a wiring diagram but I think the wire colors are the same for both they are just in different positions. You can remove the wires from the original plug by using a tiny screwdriver to press the barb and pull the wire free from the original plug then pop it back in to the correct position in the new plug. This has to be done carefully, one wire in the wrong place could be bad.
Old Oct 25, 2010 | 06:14 PM
steponit's Avatar
steponit
If you have a cluster with all gauges you need the harness that supplies information all the gauges.
It will be a direct fit with no alterations as long as the harness matches the cluster.
You will also need the sending units for gauges as well
The sending units for warning lights are different
eviiltim72
Feb 1, 2014 09:03 PM
Gembone
17
Aug 1, 2013 05:55 PM
blueovalfan1
Sep 15, 2011 04:53 PM
73FOMO
Dec 10, 2010 11:27 AM
Don_Brody
Bronco II
Oct 25, 2004 08:47 AM
