2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
rough shacking
Old Dec 16, 2013 | 10:31 PM
ffexpedition07's Avatar
ffexpedition07
rough shacking
hello everyone, i have a 07 expedition 5.4 w/ 117,xxx miles on it. i started shaking at speeds of 30-50 mph. it shacks like a misfire but no misfire code. it only does this when it has shifted through all gears, and turning O/D off helps alot. it doesnt have a rough idle and accelerates nice on highway, no problems at higher speeds. it only has the p0420 and p0430 codes. any help is greatly appreciated. thanks.
Old Dec 19, 2013 | 11:20 PM
xcaliber1972's Avatar
xcaliber1972
check the coils mine did the exact same thing and now runs perfectly after changing the coils
xcaliber1972
may also check the injectors
Old Dec 21, 2013 | 06:55 AM
Superred2's Avatar
Superred2
FFE07, did you ever find out what was causing the shaking?
Old Dec 21, 2013 | 08:46 PM
ffexpedition07
sorry guys haven't worked on it yet. will keep ya all posted. thanks.
Old Dec 22, 2013 | 06:28 AM
alwaysfords41's Avatar
alwaysfords41
You should look at that sooner rather than later, you run the risk of wrecking your cats. You can have lots of misfires before you get a code, you need a scan tool that can read pending codes to fully understand the shaking. By the description I'd agree with misfire caused by either a COP, a COP boot, a plug or an injector. Or multiples.
Old Aug 8, 2014 | 01:47 PM
OUFan22's Avatar
OUFan22
Evidently I waited too long to have mine checked after a slight shudder I noticed some time ago. The CEL came on while on vacation and drove a long way home with it on. I originally thought it was the plugs that were fouled. It ran fine except for at about 1,500 RPM it would shudder a little bit but would stop after accelerating.
I pulled the codes when I got home and it was P0430. I took it to my mechanic because I didn't want to break any plugs off and he checked it out and confirmed that I needed to change my plugs. BUT, he said before I change my plugs I needed to change out my catalytic converters. He checked for back pressure after removing the O2 sensors and verified that the driver side catalytic converter is trashed and that the passenger side also needed to be replaced.
I will be changing out catalytic converters and then the plugs. I was planning on using universal catalytic converters instead of the costly bolt-in replacements. Any recommendations on particular brands or part numbers would be appreciated.
Old Sep 22, 2014 | 09:20 AM
cstanley44's Avatar
cstanley44
I have similar symptoms, due for plugs now so will try that first.
cookingguy
Oct 1, 2017 05:22 PM
2001f1505.4
Mar 31, 2014 09:54 AM
willtim1234
Modular V10 (6.8l)
Aug 18, 2013 11:03 AM
jdm5630
51
Feb 23, 2013 08:06 PM
XylemXorro
Sep 15, 2007 10:04 AM
