Rough idle
Old Oct 1, 2017 | 11:30 AM
cookingguy's Avatar
cookingguy
Rough idle
So i have been having a rough idle issue. All injectors are not older then 3 years. My Icp is six months old. The issue stated out as an interment issue. Every now and then once the truck is warmed up i would notice it at stop lights. Now it seems to be much more frequent. Also at times when driving it feels a little rough and kinda jerky . I notice it when the rpm is between 1200 and 2000 what do i need to be looking at? I have a scan Gauge to get some readings
Old Oct 1, 2017 | 05:22 PM
navistarnut's Avatar
navistarnut
Injectors are Ford remans?
ICP was OEM?
I would find out if you have any codes, SGII not the best code reader but you can get misfire info from it.
Try something like ForScan downloaded for free or $5 to a smartphone, then get an ELM327 for the OBD port for the wireless connection.
ForScan does a great job with codes, has a lot of nice features.
You can always check every injector harness plug for good connection, check FICM plugs X3.
Have you done the blue spring update?
kornfanjoe
Jan 16, 2015 09:36 AM
95schauf
Mar 2, 2013 09:39 AM
strokin'_tatsch
Oct 14, 2008 02:05 AM
XylemXorro
Sep 15, 2007 10:04 AM
